Can't register livepano   [SOLVED] - View the solution
42VR
Likes: 13 posts
by 42VR » Wed Dec 17, 2014 4:29 pm
hi, i just upgraded to panotour 2.3, and have to re register my livepano license.
but when i paste in my serial#, it won't do anything...i press OK, but nothing happens, and it stays unregistered.
what is wrong?
Mac OSX 10.10.1
thanks,
randy
Re: Can't register livepano  [SOLVED]
by Annis » Wed Dec 17, 2014 5:00 pm
Firstly, as a note, Panotour Pro 2.3 is not supported on Yosemite yet.
Secondly, were your licenses (PTP and Livepano) purchased under the same e-mail?
If they were, could you try pressing Enter on your keyboard after entering the key into the text field?
If they weren't, could you send an email to contact(at)kolor.com with your invoice numbers and e-mails the licenses were purchased under.
