Video size for different users
zebragruen
by zebragruen » Wed Nov 26, 2014 8:40 am
in this tour (http://talking-pano.de/haefelinger.html) I have several videos.
The pano itself is able to adjust the stream to different users like pc or smartphone or apple.
Question: How can I manage the videos to be smaller for users with p.e. a smartphone?
Thanks,
Alex
Re: Video size for different users
by benji33 » Wed Nov 26, 2014 10:01 am
Into the "display a video" action you can set a size Width or Height in %.
Set a value in % and let the other one to 0 to keep the aspect ratio of the video.
Be carreful with mobile devices many of them (older ones) doesn't accept video which are bigger than 1280x720.
zebragruen
by zebragruen » Wed Nov 26, 2014 12:03 pm
Thanks Benjamin!
Is there a relation between the displayed size of the video image and the download stream of the video?
by benji33 » Wed Nov 26, 2014 12:48 pm
Display size is just some rules to display/scale the video.
The stream is the basic width/height/compression/bandwidth/frequency of the video and audio.
zebragruen
by zebragruen » Wed Nov 26, 2014 12:53 pm
I am not shure if I understand this.
Example: on a 25' monitor I play a video in the ptp project. Let's say, fullframe.
And then I have a video an a 4' display smartphone.
They both come fome the same ptp project.
Is there a difference in the videostream? Is the stream for 25' larger then for the 4'?
by benji33 » Wed Nov 26, 2014 1:00 pm
Ok sorry.
No it's the same stream.
PTP doesn't transcode the video for each kind of device. Only the Livepano are transcoded into high resolution for desktop computer and low resolution for tablet/mobile devices.
It can be done with krpano code into the call to the displayVideo action to reach different encoded videos.
zebragruen
by zebragruen » Wed Nov 26, 2014 2:59 pm
Do you have any example or tutorial for this?
Alex
by benji33 » Wed Nov 26, 2014 4:14 pm
Generate all your different video versions.
For instance "video720p.mp4" for mobile, "video960p.mp4" for tablets and "video1080p.mp4" for desktop.
1. Add a button or a hotspot which call the "Basic > Display a video" action with the "video1080p.mp4" file.
2. Generate the tour.
3. Add "video960p.mp4" and "video720p.mp4" into the YOUTOURdata/spots/ directory.
4. Edit the YOURTOUR.xml file and look after the displayVideo string.
You should have something like that :
displayVideo(%FIRSTXML%/spots/video1080p.mp4
             ,center
             ,0
             ,0
             ,true
             ,false
             ,false
             ,true
Edit the action to use this code instead :
if(device.desktop,
             ,center
             ,0
             ,0
             ,true
             ,false
             ,false
             ,true
if(device.tablet,
displayVideo(%FIRSTXML%/spots/video960p.mp4
             ,center
             ,0
             ,0
             ,true
             ,false
             ,false
             ,true
displayVideo(%FIRSTXML%/spots/video720p.mp4
             ,center
             ,0
             ,0
             ,true
             ,false
             ,false
             ,true
zebragruen
by zebragruen » Mon Dec 01, 2014 1:00 pm
Ok, took a while, but I made the modifications you explained. Thank you, Bejamin!
Now we have the situation, that the video plays in a loop. How do I stop this?
Alex
by benji33 » Mon Dec 01, 2014 2:17 pm
This call use many parameters : displayVideo(%FIRSTXML%/spots/video1080p.mp4,center,0,0,'','',true,false,'',false,true);
1st is the video file
2nd is the position/alignment of the video into the page
3rd is the x offset value
4th is the y offset value
5th is the video width
6th is the video height
7th is the loop state of the video (true/false)
8th is the pause autorotation option (true/false)
9th is unused yet
10th is the play/pause button option over the video (true/false)
11th is the pause background sound option (true/false)
So change the 7th parameter value.
zebragruen
by zebragruen » Mon Dec 01, 2014 3:04 pm
This the section I changed.
<action name="onclickspotpoint18">
if(device.desktop,
displayVideo(%FIRSTXML%/spots/1-youtube.mp4
,center
,0
,0
,true
>> ,true <<< This was "false" at first. I changed it to "True". Both had the same result: The video played in loop.
,false
,false
What am I doing wrong?
Alex
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Mon Dec 01, 2014 3:08 pm
zebragruen wrote:This the section I changed.
if(device.desktop,
1displayVideo(%FIRSTXML%/spots/1-youtube.mp4
2 ,center
3 ,0
4 ,0
5 ,''
6 ,''
7 ,true
8 >> ,true <<< This was "false" at first. I changed it to "True". Both had the same result: The video played in loop.
,false
,false
Alex
Er... Benji says change the 7th value, you changed the 8th =D
zebragruen
by zebragruen » Mon Dec 01, 2014 3:29 pm
:cool: Man, you saved my day....
Alex
