Questions about LivePano
andy4nothin
by andy4nothin » Fri Nov 07, 2014 5:01 pm
Does the use of Live pano require Autopano, PTP and Livepano, or are there alternatives?
Is there a demo version of Livepano or does it require a licence to unlock it, in which case, how can you try before you buy?
Is Livepano limited to 1080p or can you use 4k?
Does Autopano attempt to match the video to the still regardless of size/crop factor?
In order to capture a wider video scene, would shooting landscape rather than portrait create any problems?
Re: Questions about LivePano
by mediavets » Fri Nov 07, 2014 5:13 pm
andy4nothin wrote:Does the use of Live pano require Autopano, PTP and Livepano?
Yes.
andy4nothin wrote:Is there a demo version of Livepano or does it require a licence to unlock it, in which case, how can you try before you buy?
http://www.kolor.com/wiki-en/action/vie ... ad_link.3F
andy4nothin wrote:Does Autopano attempt to match the video to the still regardless of size/crop factor?
Autopano stitches the video frame as it would any other pano.
andy4nothin wrote:In order to capture a wider video scene, would shooting landscape rather than portrait create any problems?
Not that I know of.
