Panotour including Livepano
rrmontero
by rrmontero » Sat Jul 05, 2014 7:46 pm
I would like to know what kind of video is necessary. I have a fullframe camera with 21mm lens. Could I record with this lens and then stich with Panotour?
Is it necessary record a 360º panorama video? Is it possible record only in the same way of I want record (a person for example)?
Thank you very much!!
Re: Panotour including Livepano
by mediavets » Sat Jul 05, 2014 9:36 pm
rrmontero wrote:I would like to know what kind of video is necessary. I have a fullframe camera with 21mm lens. Could I record with this lens
Yes.
You need to stitch with APG 3.x And to have a Livepano license for use with PTP 2.x.
No.
Yes, if the video frame FOV of 21mm lens is sufficient.
rrmontero
by rrmontero » Wed Jul 09, 2014 6:55 pm
Ok, Thank you very much. I will try it!!
