Multiple LivePanos on one Panorama (360ºx180º)
TRI60
by TRI60 » Sun Jun 15, 2014 2:03 pm
I do want to have multiple livepanos on one panorama. I have done one-on-one (meaning one livepano on one panorama). That's not the problem I'm facing. The wiki documentation says: "To add multiple LivePanos, import them one by one, following the 5 steps described below"
I did try that to have 3 livepanos in one panorama. Just import multiple panos on one and the same panorama. The frame location was still at the same spot. I did create with Autopano the correct files.
So I do have in the Livepano directory:
- and the pictures which were used by creating the panorama
In the directory above:
- Pano1.move
- Pano2.move
- Pano3.move
The question is: Can I use one panorama with 3 imported livepano movies at different positions in the panorama? Or its is so, that only ONE panorama can have only ONE livepano movie imported?
Likes: 14 posts
Re: Multiple LivePanos on one Panorama (360ºx180º)
by bdd » Mon Jun 16, 2014 2:09 pm
TRI60 wrote:The frame location was still at the same spot. I did create with Autopano the correct files.
What do you mean exactly ?
Does your Autopano project contains the 3 video frames ?
if yes, then you should be able to import 3 livepanos in your panorama.
