{SOLVED} PTP 2.0 + Livepano Questions...   [SOLVED] - View the solution
jarane
by jarane » Thu Apr 24, 2014 4:52 pm
Hi everyone,
I recently upgraded to PTP2.0 + Live video and have a thousand questions to which I have not been able to find answers in the forums.
These are the first 2:
1.- how many videos can Livepano integrate in one single pano?
2.- I have already created and retouched the final equirectangular images for the tour. Do I need to include the original panel shots in the resources folder, in order for Livepano to be able to integrate the videos?
Thanks in advance,
E.C.
Likes: 14 posts
Re: PTP 2.0 + Livepano Questions...  [SOLVED]
by bdd » Fri Apr 25, 2014 8:39 am
jarane wrote:1.- how many videos can Livepano integrate in one single pano?
The only limit is that the video should not overlap.
The following panorama embeds 3 livepanos : http://etvlabs.com/dev/n_gym/pano.html
jarane wrote:2.- I have already created and retouched the final equirectangular images for the tour. Do I need to include the original panel shots in the resources folder, in order for Livepano to be able to integrate the videos?
You should keep the original panel where they were when you saved the autopano project.
The livepano wizard will search them in the path indicated by the autopano project file.
jarane
by jarane » Fri Apr 25, 2014 11:56 am
Thanks, my friend!
