Vernissage / opening day
Share what you've done with Autopano Video.
Montrez nous vos oeuvres avec Autopano Vidéo.
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Wed Mar 25, 2015 10:58 am
Hi all,
my first "real" 360°-moovie:
http://www.bkg.wtal.de/ (scroll half page down)
Yes, boring 15 minutes of the opening speech, cut together from 5 Ricoh Theta 3-minute-clips.
You can hide/show the gui elements, you have several entry points (Kapitel / Chapters).
The improvised player can handle multiple "film reels", either hosted by eyes.kolor or youtube, every "reel" can have multiple entry points. And still some formatting problems when viewed with firefox, please use Chrome, IE, Safari.
Do you have any suggestions or thougts concerning my improvised gui?
greetings from germany
Cliquetsy likes this post.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Vernissage / opening day
by Cliquetsy » Wed Mar 25, 2015 11:08 am
I found it interesting (well, I didn't understand any of the German... ;) ).
If you are going to add buttons to increase/decrease the playing speed, I would recommend adding one that would get the speed back to normal, because there is no indication of the current speed other than the people talking like zombies (slow) or minions (fast).
Since there's autoplay, I can't read your "splashscreen", it goes away too fast.
The logo is distracting to change the video quality, the focus leaves the menu to focus on the logo, so I can't change the quality.
Hope this helps =)
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Wed Mar 25, 2015 11:18 am
Cliquetsy wrote:If you are going to add buttons to increase/decrease the playing speed, I would recommend adding one that would get the speed back to normal, because there is no indication of the current speed other than the people talking like zombies (slow) or minions (fast).
Good idea.
Cliquetsy wrote:Since there's autoplay, I can't read your "splashscreen", it goes away too fast.
It simply tells you that "be patient, the projectionist is changing the film reel". For viewers with slooow internet connection.
Cliquetsy wrote:The logo is distracting to change the video quality, the focus leaves the menu to focus on the logo, so I can't change the quality.
Maybe i will make two hide-buttons, one for kolor gui, one for my gui elements.
Chris
by klausesser » Sat Apr 25, 2015 6:26 pm
Christian Stüben wrote:Hi all,
Well done! Is running flawlessly!
Real pity we couldn´t meet!
by Destiny » Sat Apr 25, 2015 10:14 pm
Hi Chris.. Sorry to show you this.... and your video does not work my end..
by klausesser » Sat Apr 25, 2015 11:18 pm
Destiny wrote:Hi Chis.. Sorry to show you this.... and your video does not work my end..
Did you try Firefox? Here it runs flawlessly on Safari, Chrome and Firefox.
Maybe you´d need to check your Safari settings. Did you activate WebGL?
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Sun Apr 26, 2015 8:46 am
Destiny wrote:Hi Chris.. Sorry to show you this.... and your video does not work my end..
I´ve tested my scripts with Chrome, IE, Safari, FF on windows. My Mac is too old to install current webbrowsers.
Do you have javascript enabled?
Which OS, which Browser do you utilize?
Does the "play-button" from kolor work, or does it denie operating too?
Chris
by Destiny » Sun Apr 26, 2015 8:57 am
I am using Safari, my JS is always enabled, and so is the WebGL.. I just tested Opera and that looks the same..
by mediavets » Sun Apr 26, 2015 1:17 pm
Chris
Firefox 37.01.1 on Windows 7 Pro 64-bit.
Video works but page layout appears odd - or is it meant to look like this?:
by klausesser » Sun Apr 26, 2015 1:59 pm
mediavets wrote:Video works but page layout appears odd - or is it meant to look like this?
The layout really is a bit strange - but hey: that´s design . . :cool:
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Sun Apr 26, 2015 3:28 pm
mediavets wrote:Firefox 37.01.1 on Windows 7 Pro 64-bit.
Nope. It should look like the example Destiny showed. With some early FF versions i had similar problems, but the current version should be ok.
Greetings from germany
Chris
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Sun Apr 26, 2015 3:50 pm
I just made a quick check with my ff, 36.0.4 on win. Looks ok.
by klausesser » Sun Apr 26, 2015 6:16 pm
Christian Stüben wrote:I just made a quick check with my ff, 36.0.4 on win. Looks ok.
The attachment ff2.jpg is no longer available
Well - it´s indeed a bit strange ;) :cool:
