Slow Startup of Autopano Giga Pro on win 10   [RESOLU] - View the solution
ashwin_
by ashwin_ » Tue Jan 09, 2018 8:28 am
Hi Team
We are facing an issue with Autopano Giga pro startup. It is taking minimum 10-15 minutes to startup. Below mentioned are the system config.
perating System: Windows 10 Pro for Workstations, 64-bit
DirectX version: 12.0
GPU processor: Quadro P6000
Driver version: 386.07
Direct3D API version: 12
Direct3D feature level: 12_1
CUDA Cores: 3840
Core clock: 1506 MHz
Memory data rate: 9026 MHz
Memory interface: 384-bit
Memory bandwidth: 433.25 GB/s
Total available graphics memory: 155608 MB
Dedicated video memory: 24576 MB GDDR5X
System video memory: 0 MB
Shared system memory: 131032 MB
Video BIOS version: 86.02.1D.00.05
IRQ: Not used
Bus: PCI Express x16 Gen3
Error Correction Code (ECC): Off
Device Id: 10DE 1B30 11A01028
Part Number: G611 0500
CUDA Cores: 3840
