APP3.0 - Lancer le rendu - disparition des options avancées
yves75
by yves75 » Sat Dec 22, 2012 7:25 pm
Sauf erreur de ma part, je ne vois plus les options avancées dans le panneau 'lancer le rendu' (configuration : Windows 7, 64 bits).
Du coup, plus moyen de modifier le profil de mélange.
La mise à  jour 3.0.1. ne change rien.
S'agit-il d'un bug ou d'une subtilité dans le menu?
Bien cordialement.
Yves.
Yves
www.yvesduval-photo.net
by gkaefer » Sat Dec 22, 2012 9:12 pm
hope I understand your posting...
the settings got split. just see my screenshot.
on left side the global settings are displayed with your yellow and orange part.
in 3.0.1 the orange part remains in the render dialog you mentioned.
the yellow part got moved to the edit pano window and here localised under fusion.
Liebe Gruesse,
yves75
by yves75 » Mon Dec 24, 2012 5:01 pm
Hi Georg,
Thank you very much for your reply. I understand how it works now.
Best regards .... and merry Christmas
Yves
