Aug 18 08:17:51 macpro_ethernet_1 installd[34716]: ./postinstall: OSError: [Errno 2] No such file or directory: '/Users/vincen/Library/Application Support/Adobe/Lightroom/Modules/AutopanoGiga.lrplugin'
Aug 18 08:17:51 macpro_ethernet_1 installd[34716]: ./postinstall: /Users/vincen/Library/Application Support/Adobe/Lightroom/Modules/AutopanoGiga.lrplugin
Aug 18 08:17:51 macpro_ethernet_1 installd[34716]: PackageKit: Install Failed: PKG: post-install scripts for "com.kolor.pkg.Lightroom_plugin"\nError Domain=PKInstallErrorDomain Code=112 UserInfo=0x101e0acd0 "An error occurred while running scripts from the package “Lightroom plugin.pkgâ€." {\n NSFilePath = "./postinstall";\n NSLocalizedDescription = "An error occurred while running scripts from the package \U201cLightroom plugin.pkg\U201d.";\n NSURL = "./Contents/Packages/Lightroom%20plugin.pkg -- file://localhost/Volumes/AutopanoGiga_Beta/AutopanoGiga_Beta.mpkg/";\n PKInstallPackageIdentifier = "com.kolor.pkg.Lightroom_plugin";\n}
Aug 18 08:17:51 macpro_ethernet_1 Installer[34559]: install:didFailWithError:Error Domain=PKInstallErrorDomain Code=112 UserInfo=0x10024d2b0 "An error occurred while running scripts from the package “Lightroom plugin.pkgâ€."
Aug 18 08:17:51 macpro_ethernet_1 Installer[34559]: Install failed: Le programme d’installation a rencontré une erreur qui a provoqué l’échec de l’installation. Contactez l’éditeur du logiciel pour obtenir de l’aide.
Aug 18 08:17:52 macpro_ethernet_1 Installer[34559]: IFDInstallController 17130D30 state = 7
Aug 18 08:17:52 macpro_ethernet_1 Installer[34559]: Displaying 'Install Failed' UI.
Aug 18 08:17:52 macpro_ethernet_1 Installer[34559]: 'Install Failed' UI displayed message:'Le programme d’installation a rencontré une erreur qui a provoqué l’échec de l’installation. Contactez l’éditeur du logiciel pour obtenir de l’aide.'.
File "/tmp/PKInstallSandbox.pkhIWI/Scripts/com.kolor.pkg.Lightroom_plugin.MtTl9G/postinstall", line 69, in main
makeDir( paths[d] )
File "/tmp/PKInstallSandbox.pkhIWI/Scripts/com.kolor.pkg.Lightroom_plugin.MtTl9G/postinstall", line 18, in makeDir
os.mkdir( path )
gifa wrote:il faut créer manuellement le dossier Modules dans /Users/vincen/Library/Application Support/Adobe/Lightroom
