#1 2010-08-25 19:25:02
Website
Templete made in beta9 not working in beta10
Hi!
I generated a template in beta09 which isn´t working in beta 10 - i copied it into the template folder and copied modified buttons into the menu folder.
Nevertheless the default template and the default buttons appear in the html window when opened in browser.
here´s my modified template:
Code:
<body bgcolor="#454545">
    <div align="center">
        <table width="100%" border="0" cellspacing="2" cellpadding="0" height="100%">
            <tr>
                <td bgcolor="#333333" width="100%"></td>
            </tr>
            <tr height="500">
                <td width="100%" height="500">
<object width="900" height="500">
<embed src="$(SWF)" width="900" height="489" allowFullScreen="true">
</embed>
</object>
    </td>
            </tr>
            <tr>
                        <p><font color="#969696">Bitte bewegen Sie sich mit gedr&uuml;ckter Maustaste im Bild umher.</font></p>
                        <p><font color="#969696">Zoomen mit Scrollrad oder Tasten.</font></p>
                        <p></p>
                    </div>
                </td>
            </tr>
        </table>
    </div>
</body>
#2 2010-08-26 11:20:31
Adrien F
Re: Templete made in beta9 not working in beta10
Hi Klaus,
Could you be more specific for your problem : which template is not working? the HTML one or the menu one? And what is not working? maybe an example could help describing it all. thanks.
I spotted an error in your HTML template :
l.9  there is an unclosed <div> tag around the object embedding tags.
regards,
Adrien
#3 2010-08-26 12:35:18
Website
Hi Adrien!
I made a html-templete in beta7 and it works fine. Copied it - and the altered menu items - into beta10.
Now i expected the results of beta10 to look like the result in beta7. But it keeps the default look.
But if i missed an item as you say that might be the reason! I´l check it.
Thanks!
#4 2010-08-26 15:16:31
Website
Hi Adrian!
Can´t find it!
P.S.: found another way! Thanks again.
