#1 2010-06-14 08:08:07
b4de4nd
[APT Beta7] Graphics Problem
Hi guys!
Ive been using the autopano tour beta7 a couple of days. Great Software ! smile
However ive been trying to make my own graphic icons for navigation. That works well, thus there is an malfuntion i cant seem to get my head around.
When i load the pano tour the last 2 icons looks like the been greyed out, or the opacity is set lower then the rest of the icons.
http://www.kdfoto.dk/autotour_beta7.jpg
The icons are all the same when i look at them in photoshop. So is the tour program doing anything to them when reading and writing them into a created tour ??
Thx in advance...
#2 2010-06-14 09:21:50
Adrien F
Re: [APT Beta7] Graphics Problem
This surely has something to to with the blendmode property :
krpano doc:
http://www.krpano.com/docu/xml/#plugin
All blend modes available :
http://livedocs.adobe.com/flex/201/lang … dMode.html
examples:
http://livedocs.adobe.com/flex/201/lang … #blendMode
#3 2010-06-14 09:22:22
Adrien F
I mean, you have to check the xml template menu of course.
#4 2010-06-14 10:45:11
Website
b4de4nd wrote:
Hi guys!
Thx in advance...
When you get your krpano license you will be able to externalise the XML generated by APT and then maybe it will be easier to figure out what's happening here.
Did you create a custom navigation menu XML template file or just subsitute your graphics for the default button graphic set?
#5 2010-06-14 18:23:48
b4de4nd
i found the xml file for the template and have edited in the original simplewithfullsreen.html
However i have only changed the icons input folder and made a new folder in the program called b4de4nd
Blend mode an all other settings are like they were from the original file...
And the original file has screen, add, and normal stated in the respective codes for in and out... changed all of them to normal and will export to see if it has changed now ...
Thx for the pointer... missed that one with blending mode smile
#6 2010-06-14 18:34:14
b4de4nd
works like a charm now big_smile
Now i only need to add javascript to the output code wink
#7 2010-06-14 18:39:35
b4de4nd
and thats added trough the html file : )
But what the code for making the autorotate start as default
AutoRotate="true" ?
