#1 2010-02-04 01:01:45
JohnM
[APT beta 7] - External links from hotspots not working
Hotspots with external links dont seem to work when using 2 panos and several hotspots with external links.
May anyone reproduce as a bug ?
John Myrstad
#2 2010-02-04 13:00:16
Website
Re: [APT beta 7] - External links from hotspots not working
John Myrstad
Several hotspots each to an external link in each pano?
#3 2010-02-05 01:07:47
JohnM
Yes, but I have just added hotspots to one pano atm.
#4 2010-02-05 01:30:13
Website
Just done a quick test.
Two panos in the tour. Each has three hotspots, one of each type (polygon, rectangular and point) and each with a different external link.
It all works fine in Firefox on Windows XP SP3.
I'm using the latest version of APT - V1.1 beta 7:
http://www.autopano.net/forum/t7116-apt-v1.1-beta
#5 2010-02-11 05:05:02
BrianLR
Website
John Myrstad
John,
Yes I can confirm this, I have had a problem accessing external URLS from hotspots. I have noticed this for some time, with versions APT 1.1.0 beta 6 & 7, using IE and Firefox on Windows 7.
Brian
Brian  - http://PhotoWebLab.zenfolio.com
Nikon D600, D300, Nikkor 10.5mm, Sigma  15mm, Sigma 10-20mm, Nikkor 18-70mm, Nikkor 24-85mm VR,
Nikkor 50mm f/1.8, Nikkor 55-200mm VR, Tokina 80-400mm, AutoMate, Nodal Ninja 3 Mk II with RD-16, Nodal Ninja RD1
Cyber-PC Intel Core i7-2600K, 32GB RAM, GeForce GTX 560 Ti 1GB DDR5, 240GB SSD, 2 x 450Gb VelociRaptor RAID 0, 2 x2 TB HDD RAID 0
#6 2010-02-11 09:15:50
Website
John Myrstad
John,
Brian
Is there anything unusual about those problem URLs? Some 'odd' syntax, perhaps?
I had no problems with hotspots linking to external URLs when conducting a quick test using Beta 7 and FF with Windows XP:
http://www.autopano.net/forum/p58401-20 … -13#p58401
#7 2010-02-11 15:26:25
BrianLR
Website
mediavets wrote:
Brian
MediaVets, I have tried several urls and none work, here are two of the urls that I have tried that do not work, please could you try them and see if they work or not on your system, the syntax on these does not look unusual.
http://photoweblab.zenfolio.com/img/v3/p210754829-2.jpg
http://www.saudiaramcoworld.com/issue/2 … efault.htm
#8 2010-02-11 16:18:47
Website
BrianLR wrote:
mediavets wrote:
Brian
Brian,
Now I am very confused.
I created a new tour with hotspots linking to your URLs.
The hotspots don't work, on local playback.
I checked that my test tour I did the other day with hotspots linked to external URLs still worked - and it does.
I hand edited the XML for the above working example and changed my original URLs to your URLs on the hotspots - and it works, the hotspots link to your external URLs just fine on local playback..
I am now at at a loss to explain what's going on.
Andrew
#9 2010-02-11 20:16:45
Website
Brian,
I have been 'playing' some more with your issue of hotspots linked to external URLS.
I find that tours with hotspots lined to external URLs that don't work when played back locally do work when published to the Web.
I still have one tour that works when played back locally.
Why that one tour does work when played back locally and others only when published to the Web is  beyond my understanding.
Perhaps Adrien can explain it?
#10 2010-02-12 10:40:14
Adrien F
Unfortunately I haven't been able to reproduce this behavior, nor locally, nor on external servers.
Thus it will be quite difficult to investigate it. We think this may be due to text encoding of URL in xml.
Could anyone who reproduced the bug tell us :
embedding xml or not?
which browser?
if known : which text encoding in web browser and in text editor?
thanks
#11 2010-02-19 04:19:46
BrianLR
Website
which browser?
thanks
Adrien
XML was embedded
IE 8 and Firefox 3.5.7
How would I find the answer to "which text encoding in web browser and in text editor?"
Brian
#12 2010-04-21 10:53:12
gerpho
Website
Hi
Same problem with the "logo" feature. The link to a website does not work. Operated locally on firefox last version, XP SP3.
Bonne chance pour cette recherche difficile !
Philippe
