#1 2009-04-30 02:35:37
DrSlony
Website
[APG-2.0.0 Linux64] no HDR color correction mode
I loaded all the images from this pano and as you saw it was detected and stitched perfectly, but I couldn't enable HDR color correction mode. I tried sorting images by bracket in the layers panel and turning on "optimize by layers" color correction but that didn't make any difference, HDR was still greyed out. X crashed out later completely so I will redo this and post screenshots later.
----edit
Possibly caused by this error in Image Properties. All the images had all the required EXIF data, Autopano missed some tags and incorrectly rounded off others, as I described in this thread below. Alexandre I hope you still have the 4GB archive from me to verify smile If you need, I can also just zip 3 images - 1 that was detected well, 1 whose speed value was rounded off incorrectly, and 1 whose speed value is not shown at all in image properties.
http://www.autopano.net/forum/t5855-apg … ties-panel
----edit2
Missing values both for my .pef and .tiff files.
----edit3
I added 1/5 to all the missing values and detected, but HDR mode still not active.
Uploaded Images
#2 2009-05-04 17:00:41
DrSlony
Website
Re: [APG-2.0.0 Linux64] no HDR color correction mode
Bump, bug case opened or ignored?
Could this influence color correction? I'm sure it influenced HDR color correction in 1.4.2 but APG-2.0.0 only has LDR.
#3 2009-05-05 18:46:17
Kolor CEO
Website
I wasn't able to reproduce on linux.
The HDR is activable and every image have speed / aperture value.
Uploaded Images
#4 2009-05-05 19:54:19
DrSlony
Website
I tried the binary and the shell script, I tried using "select images" from the main toolbar so that stacks are detected, and I tried creating a new group manually and clicking "add images" so that no stacks are created, but no luck, HDR was always greyed out.
Could you upload your .pano file somewhere so that I can try it?
Any chance that this is related to the missing/wrong speed values?
