#1 2009-04-20 01:13:41
Website
[APG RC2 WinXP32 GPU] Problem with FE convertor on Nikon P5100
12 images shot with Nikon P5100 compact with FC-E8 FE convertor - 4-around with AEB of 3 steps, -1/0/+1:
http://www.three60views.org.uk/image_se … 100aeb.zip
Nothing in EXIF to indicate FE convertor in use, so used Image settings to chnage lens type an sset crop circle.
Go to stitch and program thows up error claiming I'm mixing FE and standard lens images.
Uploaded Images
#2 2009-04-20 17:04:46
Website
Re: [APG RC2 WinXP32 GPU] Problem with FE convertor on Nikon P5100
I've been looking at this further and have discovered something that may be relevant.
Screenshot 1 - shows image settings after I changed the lens type from standard to fisheye and set the crop circle.
Screeshot 2 - shows the Group pane as I am about to choose to display image details.
Screenshot 3 - shows the image details - two things stand out a) the lens type is listed as standard and b) the date is missing.
Uploaded Images
#3 2009-04-21 09:35:36
Kolor CEO
Website
I tried a lot of combination to try to reproduce this one without luck.
( There's display bug for the lens type and date in detail view, I agree for that one ).
#4 2009-04-21 10:16:53
Website
Nor can I now - weird.
OK.
Please also see this report which seems to be a related issue:
http://www.autopano.net/forum/t5910-apg … -behaviour
#5 2009-05-18 10:29:34
Website
I have this bug again in 2.0.1:
http://www.autopano.net/forum/p43243-20 … -41#p43243
But it doesn't happen all the time - I'm trying to isolate the circumstances in which it occurs.
Uploaded Images
