#1 2009-03-23 17:03:37
oliv33
problem for stichting with hdr files
hello
does someone already seen these kind of bad stitching?
http://f.imagehost.org/t/0748/autopano.jpg
i had this issue a few times since i'm using autopano and do'nt understand why the picture goes like that:
http://g.imagehost.org/t/0861/autopano2.jpg
any help or explanations are welcome wink)
#2 2009-03-23 18:44:07
DrSlony
Website
Re: problem for stichting with hdr files
It happens when control points are badly placed and you have "lens distortion" enabled. Either fix your CPs, or disable "lens distortion", or both.
#3 2009-03-23 18:55:19
Kolor CEO
Website
Yes, this is typical of some wrong control point ( or a wrong link ). Check the panorama, reoptimize and you are done.
#4 2009-03-23 20:35:50
oliv33
hey!
i disabled "lens distorsion" and it's much more better!
thanks a lot big_smile
#5 2009-03-23 20:39:38
Website
oliv33 wrote:
hey!
I think you may find this video tutorial interesting and helpful too:
http://www.autopano.net/wiki/action/vie … _panoramas
You can find more tutorials and information here:
http://www.autopano.net/wiki/action/view/Main_Page
Have fun!
#6 2009-03-24 02:33:21
digipano
When or what is the fit case to enable Lens Distortion?
#7 2009-03-24 08:08:20
Kolor CEO
Website
Lesn distortion is the fact of correcting pincushion distortion or so.
When shooting long focal, it can often be disabled ( 100 mm or more ).
The shorter the focal, the more you need it. It will also depend on the quality of your lens.
For fisheye, you definitively need it.
#8 2009-03-24 14:35:32
digipano
So shooting with 10mm I should keep it enabled, that's what I do.
#9 2009-03-24 15:27:41
Kolor CEO
Website
Yes.
