#1 2009-02-01 00:54:49
Deckker
Need help with 60 gig+ of Photos
Hello All,
I am trying to attempt at a Gigapixel HDR shot. My Autopan Pro has being crashing when I try to detect the pano. It is about 200+ Photos from my H3DII-50, where each file size is about 300mb each(8176 * 6132 Tiff 16bit, PhotoRGB), so its about 60+ gig of actual data.
Now I have read the FAQ on handling such panos. I am Wondering if anyone else is having trouble with this?
I run a 8 core Mac with 16 gig of Ram, should be enough Hardware.
#2 2009-02-01 01:00:14
Tim.Lewis
Re: Need help with 60 gig+ of Photos
I would suggest HDR first with Photomatix Pro, then Pano with Autopano Pro.  I find it works nicely for me.
An extra step with each set, I agree, but the control on the HDR section is good.
Plus ça change, plus c'est la même chose.
#3 2009-02-01 01:13:41
jmardy
My only suggestion is to lower your keypoints per image pair and try disabling "Strong Algorithm".
Also disable the Automate functions during the initial Detection.
That's really a shot in the dark though.
However you work this out, please post the result!
cool
#4 2009-02-01 01:33:07
Deckker
Thanks for the advice, I am currently waiting on Auto-Pano to finish its current attempt at detection before I try all this out. It takes about 2 hrs for the program to crash on me.
This is my 1st real Pano attempt with this camera, so I was merely shooting the view from my Roof. Its a wonderful view, see how it turns out.
#5 2009-02-01 02:43:17
Deckker
Ok I got the system to detect the panos, but It is now showing any panos for me to edit.
#6 2009-02-01 02:50:06
jmardy
Make sure under the View menu it says "Split 50%" or hit Command 2.
It may be that the "Panos" window isn't showing?
Or do you have an empty Panos window after detection?
#7 2009-02-01 03:22:43
Deckker
Sorry I did not notice my error.
The Panos are not showing.... I am in Spilt 50% mode.
It loads, located the pano and then it does not display anything after that, even hitting the render button produces no results.
#8 2009-02-01 14:25:21
Deckker
Allright this is annoying.
I have loaded every combination I can think, I have loaded manuelly on the needed photos, I drop the bit dept and colour space, it will either crash, or detect the panos, but will not display them in any shape or form.
What is the actually upper limit of the Pano software, because I have thrown it 15 gig smallest to 120 gig of photos and it will get so far as attempt to run the projection of the 1st pano and then the pano all vanish as if its not there. It says it found X panos, but there are no panos.
#9 2009-02-01 17:00:45
digipano
Its indeed a huge data
What version of APP are you running? there is alpha 2 which you may try, its quite improved version but still has bugs to be sorted out. (no mac version yet)
Doing this with 1.4.2 (x64 version) may work better.
#10 2009-02-01 17:02:27
l_archi
APP cluster mode ? smile
#11 2009-02-01 21:56:14
Deckker
I am running 1.4.2. I manage to find the Pano files it created, and when I load them back in Manually, they sometimes 15% success rate, they pop back up.
#12 2009-02-01 22:49:03
Website
Deckker wrote:
Hello All,
Hi Deckker!
I know the H3D very well - it´s a great camera. But i wouldn´t use it for stitching - though it seems to be logical.
A way to use it would be to lower the numbers of shots. In the end it provides no more quality than a 5DMkII using a larger amount of shots.
No difference in the end.
Generating HDR FIRST in Photomatix is my standard advice. Photomatix also is somewhat limited using very big amounts of pictures in HighDefinition.
HDR makes shooting @16bit obsolete - blowing up the files is the only effect. You´re generating 32bit anyway by processing HDR. 8bit shooting is by far enough - especially using a H3D.
#13 2009-02-02 04:48:51
digipano
I agree with klaus,
16 bit tiff that too in photoProRGB, are you shooting a scene which has all the outer shades of the color gamut which cant be produced in srgb?
You may convert your files to 8bit jpeg saved @12 (photoshop quality) & then try your hdr.
#14 2009-02-02 07:12:15
Deckker
I have given up on the HDR part right now, I just want it to render.
I have already spend so much effort on it, I would like to finish it up if at all possible. I do not own a 5DMkII, I shoot a Nikon D300.
#15 2009-02-02 13:12:03
Website
Oh yes, i do completely understand, Deckker winkcool
A D300 does it as fine as a 5DMkII/III or a H3D . . . . you just have to shoot some more pictures. Though the number of pictures is higher of course, the handling nevertheless "flows" better. At least that´s my experience after using a (rented) H3D for stitching.
But in some cases of course it´s essential to have as few shots as possible - here a H3D is a great advantage.
I had an assignment to shoot fast moving scenes for 7m print-outs @150dpi.
In that case even a H3D didn´t match. I shot analog using a 6x17cm camera and drumscanned the Velvia trannies - perfect highrez.
#16 2009-02-02 15:27:32
Deckker
LOL....In the end you choose the write tool for the right job. Nothing beats a Large Format Camera with Slide film for quality.
This Pano I am making is a night shot of the city from my roof to see how it renders, before I do one for the entire Sydney CBD.
But if it can't handle these files, I can't possible imagine handling D300 with that much more photos and just as much harddisk space used.
I will take you up on your advice, but for now I do not want to waste my existing work. I have rendered a smallish 1.7 gig pano in really crappy colour, but I do not want all the work to look like it went to waste.
#17 2009-02-02 17:03:30
digipano
You may be tempted to use APP assuming its "fill it-shut it-forget it" application but its not the case.
Its quite quick & automatic in most task but under the hood it has a lot of buttons & knobs which will require for the job which you are feeding to it & that also needs a "very good" understanding of those buttons. Without this understanding you or any other will feel dejected with APP.
Few Suggestion I have
1. please post the screen shots that helps all of us to know what are we dealing with.
2. either use 16 bit tiffs & no hdr
or
use 8bit jpeg & do HDR with separate application which can handle gigapixel files. (I can help in that)
3. HDR within APP is not great so I wont go that route.
4. Load all your 8bit HDR jpegs & stitch the 3 layers separately sorting them by bracket & don't do any color correction with APP.
Yes & no
Depends on how good are you with large format vs gigapixel stitching.
My panoramic journey started bcoz I saw few "large format" images which were stunning but later the photographer who was excellent in lens design theory told me that all the images were stitched & rendered in rectilinear projection, too perfect to believe my eyes which was wondering what lens was used for those images.
Several years ago he used D1x with Nikon 85/105/55mm lenses which threw many large format to shame, now if he has to do this with your H3DII-50, I can imagine his results.
Hope you can get some help in doing this project successfully, most members will be happy to do so.
#18 2009-02-02 23:15:25
Deckker
Well Digpano, that is an excellent point I should keep that in mind.
As for my problem, I wish I could give you a screen shot, there is no error message unless I gave you my Macs's Core dump of it. As of now, it will open, load the .pano file, start rendering and then quit without warning.  I will see what I can do to show you the error.
I am not using APP to do HDR anymore. I am following everyone's advice here.
I have attempted several different format combination.
16bit tiff PhotoRGB
16 bit tiff AdobeRGB
8 bit tiff AdobeRGB (Testing this now)
8 bit tiff srgb
the 8bit SRGB worked, but the colors are really bad in this one.
Anyhow, I will take your advice and read up more on APP.
Here are the settings I am using now
http://www.tiny-titan.com/private/pic1.png
http://www.tiny-titan.com/private/pic2.png
#19 2009-02-02 23:31:19
Deckker
Here is the Report of the Crash I just got.
Process:         AutopanoPro [9358]
Path:            /Applications/AutopanoPro.app/Contents/MacOS/AutopanoPro
Identifier:      com.kolor.AutopanoPro
Version:         ??? (142)
Code Type:       X86 (Native)
Parent Process:  launchd [138]
Date/Time:       2009-02-03 09:29:09.026 +1100
OS Version:      Mac OS X 10.5.6 (9G55)
Report Version:  6
Exception Type:  EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread:  7
Thread 0:
0   libSystem.B.dylib                 0x967301c6 mach_msg_trap + 10
1   libSystem.B.dylib                 0x967379bc mach_msg + 72
2   com.apple.CoreFoundation          0x940590ae CFRunLoopRunSpecific + 1790
3   com.apple.CoreFoundation          0x94059cd8 CFRunLoopRunInMode + 88
4   QtGui                             0x009b7683 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 569
5   QtCore                            0x01442104 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 54
6   QtCore                            0x01442223 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 109
7   QtCore                            0x01443f63 QCoreApplication::exec() + 147
8   com.kolor.AutopanoPro             0x00020dbf 0x1000 + 130495
9   com.kolor.AutopanoPro             0x00020e50 0x1000 + 130640
10  com.kolor.AutopanoPro             0x00004682 0x1000 + 13954
11  com.kolor.AutopanoPro             0x000045a9 0x1000 + 13737
Thread 1:
3   com.apple.CoreFoundation          0x94059d34 CFRunLoopRun + 84
4   com.apple.DesktopServices         0x95b40e83 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 123
5   ...ple.CoreServices.CarbonCore    0x90fbe10b PrivateMPEntryPoint + 56
6   libSystem.B.dylib                 0x96761095 _pthread_start + 321
7   libSystem.B.dylib                 0x96760f52 thread_start + 34
Thread 2:
4   com.apple.DesktopServices         0x95b40ffc TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 216
Thread 3:
0   libSystem.B.dylib                 0x967373ae __semwait_signal + 10
1   libSystem.B.dylib                 0x96761d0d pthread_cond_wait$UNIX2003 + 73
2   ...ple.CoreServices.CarbonCore    0x90fbfef7 TSWaitOnCondition + 126
3   ...ple.CoreServices.CarbonCore    0x90f9ee36 TSWaitOnConditionTimedRelative + 202
4   ...ple.CoreServices.CarbonCore    0x90fbfb74 MPWaitOnQueue + 208
5   com.apple.DesktopServices         0x95b4bfba TNodeSyncTask::SyncTaskProc(void*) + 84
6   ...ple.CoreServices.CarbonCore    0x90fbe10b PrivateMPEntryPoint + 56
7   libSystem.B.dylib                 0x96761095 _pthread_start + 321
8   libSystem.B.dylib                 0x96760f52 thread_start + 34
Thread 4:
0   libSystem.B.dylib                 0x96760906 kevent + 10
1   libSystem.B.dylib                 0x96761095 _pthread_start + 321
2   libSystem.B.dylib                 0x96760f52 thread_start + 34
Thread 5:
0   libSystem.B.dylib                 0x9677f6f2 select$DARWIN_EXTSN + 10
Thread 6:
0   libSystem.B.dylib                 0x96730226 semaphore_timedwait_signal_trap + 10
1   libSystem.B.dylib                 0x967621ef _pthread_cond_wait + 1244
2   libSystem.B.dylib                 0x96763a73 pthread_cond_timedwait_relative_np + 47
3   com.apple.Foundation              0x93c6775c -[NSCondition waitUntilDate:] + 236
4   com.apple.Foundation              0x93c67570 -[NSConditionLock lockWhenCondition:beforeDate:] + 144
5   com.apple.Foundation              0x93c674d5 -[NSConditionLock lockWhenCondition:] + 69
6   com.apple.AppKit                  0x91500d90 -[NSUIHeartBeat _heartBeatThread:] + 753
7   com.apple.Foundation              0x93c217ed -[NSThread main] + 45
8   com.apple.Foundation              0x93c21394 __NSThread__main__ + 308
9   libSystem.B.dylib                 0x96761095 _pthread_start + 321
10  libSystem.B.dylib                 0x96760f52 thread_start + 34
Thread 7 Crashed:
0   libSystem.B.dylib                 0x9680bc7e nanosleep$NOCANCEL$UNIX2003 + 0
1   libSystem.B.dylib                 0x96805013 usleep$NOCANCEL$UNIX2003 + 61
2   libSystem.B.dylib                 0x9681c685 abort + 85
3   libstdc++.6.dylib                 0x951a8005 0x95160000 + 294917
4   libstdc++.6.dylib                 0x951a610c __gxx_personality_v0 + 1108
5   libstdc++.6.dylib                 0x951a614b std::terminate() + 29
6   libstdc++.6.dylib                 0x951a6261 __cxa_throw + 101
7   com.kolor.AutopanoPro             0x000ffa64 0x1000 + 1043044
8   com.kolor.AutopanoPro             0x000ffdeb 0x1000 + 1043947
9   com.kolor.AutopanoPro             0x000ffeb0 0x1000 + 1044144
10  com.kolor.AutopanoPro             0x001ab8df 0x1000 + 1747167
11  com.kolor.AutopanoPro             0x001d5376 0x1000 + 1917814
12  com.kolor.AutopanoPro             0x001d5fde 0x1000 + 1920990
13  com.kolor.AutopanoPro             0x001afb9e 0x1000 + 1764254
14  com.kolor.AutopanoPro             0x001afda4 0x1000 + 1764772
15  com.kolor.AutopanoPro             0x001a2ca1 0x1000 + 1711265
16  com.kolor.AutopanoPro             0x001a2ff4 0x1000 + 1712116
17  com.kolor.AutopanoPro             0x002e1014 0x1000 + 3014676
18  com.kolor.AutopanoPro             0x000fd20a 0x1000 + 1032714
19  com.kolor.AutopanoPro             0x000c8113 0x1000 + 815379
20  QtCore                            0x01398faa QThreadPrivate::start(void*) + 190
21  libSystem.B.dylib                 0x96761095 _pthread_start + 321
22  libSystem.B.dylib                 0x96760f52 thread_start + 34
Thread 8:
0   libSystem.B.dylib                 0x96739a5e munmap$UNIX2003 + 10
1   libSystem.B.dylib                 0x967362cd free + 106
2   com.kolor.AutopanoPro             0x001b1cb6 0x1000 + 1772726
3   com.kolor.AutopanoPro             0x0019eb27 0x1000 + 1694503
4   com.kolor.AutopanoPro             0x002d16cf 0x1000 + 2950863
5   com.kolor.AutopanoPro             0x000f7a05 0x1000 + 1010181
6   QtCore                            0x01398faa QThreadPrivate::start(void*) + 190
Thread 9:
0   com.kolor.AutopanoPro             0x002d2735 0x1000 + 2955061
1   com.kolor.AutopanoPro             0x000f4270 0x1000 + 995952
2   com.kolor.AutopanoPro             0x000f6d1e 0x1000 + 1006878
3   QtCore                            0x01398faa QThreadPrivate::start(void*) + 190
4   libSystem.B.dylib                 0x96761095 _pthread_start + 321
5   libSystem.B.dylib                 0x96760f52 thread_start + 34
Thread 10:
0   libSystem.B.dylib                 0x9673020e semaphore_wait_signal_trap + 10
1   libSystem.B.dylib                 0x96762206 _pthread_cond_wait + 1267
2   libSystem.B.dylib                 0x967a7539 pthread_cond_wait + 48
3   QtCore                            0x01399ec8 QWaitCondition::wait(QMutex*, unsigned long) + 310
4   com.kolor.AutopanoPro             0x000f6570 0x1000 + 1004912
5   QtCore                            0x01398faa QThreadPrivate::start(void*) + 190
Thread 11:
0   com.kolor.AutopanoPro             0x0038a7d2 Interpolator<unsigned short>:big_smileo(float*, KImage&, int, int, int, float, float, int, float) + 626
1   com.kolor.AutopanoPro             0x000f46c1 0x1000 + 997057
Thread 12:
0   com.kolor.AutopanoPro             0x000e50b7 0x1000 + 934071
1   com.kolor.AutopanoPro             0x000f44b3 0x1000 + 996531
Thread 13:
0   com.kolor.AutopanoPro             0x000e5057 0x1000 + 933975
Thread 14:
Thread 15:
Thread 16:
3   ...ple.CoreServices.CarbonCore    0x90f9ee62 TSWaitOnConditionTimedRelative + 246
5   com.apple.DesktopServices         0x95b4df04 TFolderSizeTask::FolderSizeTaskProc(void*) + 104
Thread 7 crashed with X86 Thread State (32-bit):
  eax: 0xb0434968  ebx: 0x9681c639  ecx: 0x00000000  edx: 0x00000000
  edi: 0xa07a95b8  esi: 0x00002710  ebp: 0xb0434978  esp: 0xb043494c
   ss: 0x0000001f  efl: 0x00010202  eip: 0x9680bc7e   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
  cr2: 0x154cd000
Binary Images:
    0x1000 -   0x4d826f +com.kolor.AutopanoPro ??? (142) /Applications/AutopanoPro.app/Contents/MacOS/AutopanoPro
  0x602000 -   0x6517fb +QtXml ??? (???) /Applications/AutopanoPro.app/Contents/Frameworks/QtXml
  0x95c000 -   0xf740a7 +QtGui ??? (???) /Applications/AutopanoPro.app/Contents/Frameworks/QtGui
0x12b8000 -  0x1345648 +QtNetwork ??? (???) /Applications/AutopanoPro.app/Contents/Frameworks/QtNetwork
0x1390000 -  0x14de563 +QtCore ??? (???) /Applications/AutopanoPro.app/Contents/Frameworks/QtCore
0x1521e000 - 0x15230fff  libTraditionalChineseConverter.dylib ??? (???) <62db211c07419a0432254a86fcc96587> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x15234000 - 0x15242feb  libSimplifiedChineseConverter.dylib ??? (???) <a506528715475cff6c623675f3a72bf8> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x15565000 - 0x1556fffe  com.apple.URLMount 3.1.1 (3.1.1) <b4018e683fad4259ee78070e91f35029> /System/Library/PrivateFrameworks/URLMount.framework/URLMount
0x15588000 - 0x1558dff3  libCGXCoreImage.A.dylib ??? (???) <375e0cdb64b043378dbf637992bbfeb0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x16341000 - 0x16357fff  libJapaneseConverter.dylib ??? (???) <1e92e348e73fc6fce723936c11e4b25c> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x2004f000 - 0x20245fff  com.apple.RawCamera.bundle 2.0.12 (421) <02fe3f4ea6251f7b2d23d855ce5c5fd2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x8fe00000 - 0x8fe2db43  dyld 97.1 (???) <100d362e03410f181a34e04e94189ae5> /usr/lib/dyld
0x90003000 - 0x90003ffe  com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <a2b462be6c51187eddf7d097ef0e0a04> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x90004000 - 0x9000bff7  libCGATS.A.dylib ??? (???) <386dce4b28448fb86e33e06ac466f4d8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x9000c000 - 0x90086ff8  com.apple.print.framework.PrintCore 5.5.3 (245.3) <222dade7b33b99708b8c09d1303f93fc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x90087000 - 0x90152fff  com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x90153000 - 0x901dfff7  com.apple.LaunchServices 290.3 (290.3) <6f9629f4ed1ba3bb313548e6838b2888> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x901e6000 - 0x90583fef  com.apple.QuartzCore 1.5.7 (1.5.7) <2fed2dd7565c84a0f0c608d41d4d172c> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90c0b000 - 0x90c4afef  libTIFF.dylib ??? (???) <3589442575ac77746ae99ecf724f5f87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x90c4b000 - 0x90c6ffff  libxslt.1.dylib ??? (???) <0a9778d6368ae668826f446878deb99b> /usr/lib/libxslt.1.dylib
0x90c70000 - 0x90cfbfff  com.apple.framework.IOKit 1.5.1 (???) <f9f5f0d070e197a832d86751e1d44545> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90cfc000 - 0x90d3dfe7  libRIP.A.dylib ??? (???) <5d0b5af7992e14de017f9a9c7cb05960> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x90d3e000 - 0x90de5feb  com.apple.QD 3.11.54 (???) <b743398c24c38e581a86e91744a2ba6e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x90de6000 - 0x90deafff  libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x90deb000 - 0x90edfff4  libiconv.2.dylib ??? (???) <c508c60fafca17824c0017b2e4369802> /usr/lib/libiconv.2.dylib
0x90ee0000 - 0x90ee0ffa  com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90ee1000 - 0x90f74fff  com.apple.ink.framework 101.3 (86) <bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x90f75000 - 0x9124fff3  com.apple.CoreServices.CarbonCore 786.10 (786.10) <ec35bb05f67fe0e828d49dda88bbf6d7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9127a000 - 0x91286ff9  com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x91287000 - 0x9129cffb  com.apple.ImageCapture 5.0.1 (5.0.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x9129d000 - 0x912a4fe9  libgcc_s.1.dylib ??? (???) <a9ab135a5f81f6e345527df87f51bfc9> /usr/lib/libgcc_s.1.dylib
0x912a5000 - 0x912c0ffb  libPng.dylib ??? (???) <4780e979d35aa5ec2cea22678836cea5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9140a000 - 0x9140ffff  com.apple.CommonPanels 1.2.4 (85) <ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x91410000 - 0x91459fef  com.apple.Metadata 10.5.2 (398.25) <e0572f20350523116f23000676122a8d> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9145a000 - 0x91c58fef  com.apple.AppKit 6.5.6 (949.43) <a3a300499bbe4f1dfebf71d752d01916> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x91c61000 - 0x91d11fff  edu.mit.Kerberos 6.0.12 (6.0.12) <685cc018c133668d0d3ac6a1cb63cff9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x91d12000 - 0x91d51fff  com.apple.CoreMediaIOServicesPrivate 12.0 (12.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x91d89000 - 0x91de2ff7  libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x91de3000 - 0x91e6aff7  libsqlite3.0.dylib ??? (???) <6978bbcca4277d6ae9f042beff643f7d> /usr/lib/libsqlite3.0.dylib
0x91e6b000 - 0x91fa3fe7  com.apple.imageKit 1.0.2 (1.0) <2e354566521df8b1e3a78e9aeab5e6b4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x91fa4000 - 0x922acfff  com.apple.HIToolbox 1.5.4 (???) <3747086ba21ee419708a5cab946c8ba6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x922ad000 - 0x922d5fff  libcups.2.dylib ??? (???) <81abd305142ad1b771024eb4a1309e2e> /usr/lib/libcups.2.dylib
0x9258f000 - 0x9259dffd  libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x9259e000 - 0x925dcff7  libGLImage.dylib ??? (???) <1123b8a48bcbe9cc7aa8dd8e1a214a66> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x925dd000 - 0x92617fe7  com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x92618000 - 0x92625fe7  com.apple.opengl 1.5.9 (1.5.9) <7e5048a2677b41098c84045305f42f7f> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x92643000 - 0x92653fff  com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <06d8fc0307314f8ffc16f206ad3dbf44> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x92659000 - 0x926cbfff  com.apple.iLifeMediaBrowser 1.0.11 (212.1.1) /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x93682000 - 0x93688fff  com.apple.print.framework.Print 218.0.2 (220.1) <8bf7ef71216376d12fcd5ec17e43742c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x93689000 - 0x93689ffc  com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x936bd000 - 0x93777fe3  com.apple.CoreServices.OSServices 226.5 (226.5) <2a135d4fb16f4954290f7b72b4111aa3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x937e6000 - 0x93828fef  com.apple.NavigationServices 3.5.2 (163) <91844980804067b07a0b6124310d3f31> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9387a000 - 0x93948ff3  com.apple.JavaScriptCore 5525.26 (5525.26.2) <69e219e81bc886a94c4d4b310d393ab9> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x93949000 - 0x93a81ff7  libicucore.A.dylib ??? (???) <18098dcf431603fe47ee027a60006c85> /usr/lib/libicucore.A.dylib
0x93c17000 - 0x93e92fe7  com.apple.Foundation 6.5.7 (677.22) <8fe77b5d15ecdae1240b4cb604fc6d0b> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x93e93000 - 0x93fe5ff3  com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93fe6000 - 0x94119fff  com.apple.CoreFoundation 6.5.5 (476.17) <4a70c8dbb582118e31412c53dc1f407f> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9411a000 - 0x9443cfe2  com.apple.QuickTime 7.5.5 (990.7) <87077cec43c7e9b02c8ee80e50b8b81f> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9443d000 - 0x94448fe7  libCSync.A.dylib ??? (???) <e6aceed359bd228f42bc1246af5919c9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94449000 - 0x94449ffd  com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9444a000 - 0x94459ffe  com.apple.DSObjCWrappers.Framework 1.2.1 (1.2.1) <eac1c7b7c07ed3148c85934b6f656308> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x9445a000 - 0x94521ff2  com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x94522000 - 0x94522ffb  com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x9456e000 - 0x9497efef  libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9497f000 - 0x949dbff7  com.apple.htmlrendering 68 (1.1.3) <fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x949ee000 - 0x949f6fff  com.apple.DiskArbitration 2.2.1 (2.2.1) <75b0c8d8940a8a27816961dddcac8e0f> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x94b77000 - 0x94b8dfe7  com.apple.CoreVideo 1.5.1 (1.5.1) <001910004257f1386724398f584b30b5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94d89000 - 0x94de3ff7  com.apple.CoreText 2.0.3 (???) <1f1a97273753e6cfea86c810d6277680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x94de4000 - 0x94e02ff3  com.apple.DirectoryService.Framework 3.5.5 (3.5.5) <f8931f64103c8a86b82e9714352f4323> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x94e03000 - 0x94e80fef  libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x94e81000 - 0x94e97fff  com.apple.DictionaryServices 1.0.0 (1.0.0) <ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x94e98000 - 0x94e9bfff  com.apple.help 1.1 (36) <b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x94e9c000 - 0x94ecbfe3  com.apple.AE 402.2 (402.2) <e01596187e91af5d48653920017b8c8e> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x94ecc000 - 0x94eccff8  com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x94ecd000 - 0x94ecfff5  libRadiance.dylib ??? (???) <8a844202fcd65662bb9ab25f08c45a62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x94ed0000 - 0x94efbfe7  libauto.dylib ??? (???) <42d8422dc23a18071869fdf7b5d8fab5> /usr/lib/libauto.dylib
0x94efc000 - 0x94f00fff  libGIF.dylib ??? (???) <572a32e46e33be1ec041c5ef5b0341ae> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x94f01000 - 0x94fe2ff7  libxml2.2.dylib ??? (???) <d69560099d9eb32ba7f8a17baa65a28d> /usr/lib/libxml2.2.dylib
0x94fe3000 - 0x94fecfff  com.apple.speech.recognition.framework 3.7.24 (3.7.24) <d3180f9edbd9a5e6f283d6156aa3c602> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x94fed000 - 0x94feffff  com.apple.securityhi 3.0 (30817) <dbe328cd62d603a952a4226342711e8b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x94ff0000 - 0x9509effb  com.apple.QTKit 7.5.5 (990.7) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x950ac000 - 0x950acff8  com.apple.Cocoa 6.5 (???) <e064f94d969ce25cb7de3cfb980c3249> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x95160000 - 0x951bdffb  libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x951be000 - 0x951c3fff  com.apple.DisplayServicesFW 2.0.2 (2.0.2) <97878a73074e7da4fe31ea010a5d5ae1> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x951c4000 - 0x951f1feb  libvDSP.dylib ??? (???) <b232c018ddd040ec4e2c2af632dd497f> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x951f2000 - 0x951f2ffe  com.apple.quartzframework 1.5 (1.5) <4b8f505e32e4f2d67967a276401f9aaf> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x952cf000 - 0x9549dff3  com.apple.security 5.0.4 (34102) <55dda7486df4e8e1d61505be16f83a1c> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9549e000 - 0x955e4ff7  com.apple.ImageIO.framework 2.0.4 (2.0.4) <6a6623d3d1a7292b5c3763dcd108b55f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x955e5000 - 0x95634fff  com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x95635000 - 0x95653fff  libresolv.9.dylib ??? (???) <a8018c42930596593ddf27f7c20fe7af> /usr/lib/libresolv.9.dylib
0x95654000 - 0x95b25f3e  libGLProgrammability.dylib ??? (???) <5d283543ac844e7c6fa3440ac56cd265> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x95b26000 - 0x95b36ffc  com.apple.LangAnalysis 1.6.4 (1.6.4) <8b7831b5f74a950a56cf2d22a2d436f6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x95b37000 - 0x95b3effe  libbsm.dylib ??? (???) <d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
0x95b3f000 - 0x95bc9fe3  com.apple.DesktopServices 1.4.7 (1.4.7) <d16642ba22c32f67be793ebfbe67ca3a> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x95bca000 - 0x95c5dff3  com.apple.ApplicationServices.ATS 3.4 (???) <8c51de0ec3deaef416578cd59df38754> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x95c5e000 - 0x95c88fff  com.apple.CoreMediaPrivate 11.0 (11.0) <e37d6ebd5934b482c864ba6eaf122488> /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x95c89000 - 0x95c95ffe  libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x95c96000 - 0x95cb3ff7  com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x95cb4000 - 0x95d51ffc  com.apple.CFNetwork 422.11 (422.11) <2780dfc3d2186195fccb3634bfb0944b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x95d52000 - 0x95e04ffb  libcrypto.0.9.7.dylib ??? (???) <69bc2457aa23f12fa7d052601d48fa29> /usr/lib/libcrypto.0.9.7.dylib
0x95e05000 - 0x95e56ff7  com.apple.HIServices 1.7.0 (???) <01b690d1f376e400ac873105533e39eb> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x95e57000 - 0x95ec9fff  com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x95f19000 - 0x95f23feb  com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x95f24000 - 0x95fa1feb  com.apple.audio.CoreAudio 3.1.1 (3.1.1) <f35477a5e23db0fa43233c37da01ae1c> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x95ff4000 - 0x96025ffb  com.apple.quartzfilters 1.5.0 (1.5.0) <22581f8fe9dd2cb261f97a897407ec3e> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x96026000 - 0x9603efff  com.apple.openscripting 1.2.8 (???) <572c7452d7e740e8948a5ad07a99602b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x96057000 - 0x96058ffc  libffi.dylib ??? (???) <a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
0x96059000 - 0x9613eff3  com.apple.CoreData 100.1 (186) <8e28162ef2288692615b52acc01f8b54> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9613f000 - 0x962fbff3  com.apple.QuartzComposer 2.1 (106.13) <40f034e8c8fd31c9081f5283dcf22b78> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x962fc000 - 0x96333fff  com.apple.SystemConfiguration 1.9.2 (1.9.2) <8b26ebf26a009a098484f1ed01ec499c> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x96334000 - 0x966f2fea  libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x966f3000 - 0x966f3ffd  com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x96724000 - 0x96724ffd  com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9672f000 - 0x96896ff3  libSystem.B.dylib ??? (???) <d68880dfb1f8becdbdac6928db1510fb> /usr/lib/libSystem.B.dylib
0x96897000 - 0x968b6ffa  libJPEG.dylib ??? (???) <e7eb56555109e23144924cd64aa8daec> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x968b7000 - 0x968b7fff  com.apple.Carbon 136 (136) <9961570a497d79f13b8ea159826af42d> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x968b8000 - 0x96998fff  libobjc.A.dylib ??? (???) <7b92613fdf804fd9a0a3733a0674c30b> /usr/lib/libobjc.A.dylib
0x96999000 - 0x969c1ff7  com.apple.shortcut 1 (1.0) <057783867138902b52bc0941fedb74d1> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x969c2000 - 0x96a41ff5  com.apple.SearchKit 1.2.1 (1.2.1) <3140a605db2abf56b237fa156a08b28b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x96a42000 - 0x970e2fff  com.apple.CoreGraphics 1.407.2 (???) <3a91d1037afde01d1d8acdf9cd1caa14> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0xbab00000 - 0xbab21fe2  libKoreanConverter.dylib ??? (???) <2f3be93c8c0872958b681397ee09c9f1> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xfffe8000 - 0xfffebfff  libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
#20 2009-02-03 03:19:22
jmardy
When in doubt, blame QuickTime:
(only half-kidding), maybe try QT 7.6?
tongue
#21 2009-02-03 04:05:07
gerardm
Website
This is an issue that I have known for awhile on the Mac platform.  Smartblend will sometimes work.  I do not know what the issue is.  If i feed it 100 images, it has a greater chance of not crashing.   My temp drive is 4 sas 15k drives.  The read and write speeds are near 500mb/sec.
#22 2009-02-03 15:29:51
digipano
Deckker,
Seeing the screen shot what I feel that the skydoes have a gradient which will need either 16bit tiffs or get jpegs processed with minimum tweaking in 8bits to do hdr.
I suggest the following.
1.raw to jpeg conversion 8bit jpegs (don't boost contrast/saturation & sharpening should be OFF completely )
2. Load all jpegs let the panorama get detected with good RMS
3. set the layers to "group by speed" & add the %L to file name now set the pano with no color correction using multiband (smartblend need more resources) Save as Jpeg 12 maximum quality.
4. Now render 1st half the size & see upto what size you can render without crashing.
4a- if at full size it still crashes the youcan rendr them 1 layer each time, for doing that you will have to go to layer window > group by speed> untick the 2 layers
4b- once you get all 3 layers rendered then we will seek hdr methods.
With these setting I guess you should be able to get a full size pano if not then try the following method.
1. At full resolution crop the pano once left half
& then the right half with 10% overlapping area.
2. now load these left & right panos & stitch them together (you would need to set the focal length manually to some 200mm onwards)
Let us know how it goes with the above suggestion.
#23 2009-02-03 16:02:23
Website
My experiences are that it seems to be easier to handle a large amount of smaller pictures than a smaller amount of big picture-files like the one coming from a H2D or a Hy6 for example.
Maybe i´m completely wrong - but i tested both of them and there were some issues when using 16bit files of about 300MB each.
#24 2009-02-04 04:02:31
Deckker
Thank guys for all the advice...I will try it out today and see what I can do.
klausesser, If what you say is true, would contacting Kolor Tech support be the best way to resolve this? Because its a problem in the code already.
#25 2009-02-09 00:13:09
Deckker
It seems that after everything, the program still crashes. I am logging a ticket.
