#1 2009-01-24 04:18:36
Ronald
Orion/Merlin interface specs...
Hi Guys,
I'm not pretty sure if I already ask for this, because, I can't find the question... anyway I will do it again, just in case...
- The RS-232 --> Bluetooth adapter sell by tronisoft is a device with special modifications, or, is an unchanged adapter?
- I'm looking for the technical specs / diagrams / design / voltage output for the 4202 PAPY in his current production batch.
This request is due the problematic situation to find /ship the adapters from tronisoft to US.
I very appreciate your help in this matter.
Best regards,
Ronald
#2 2009-01-24 10:11:31
Website
Re: Orion/Merlin interface specs...
Hello Ronald,
The Tronisoft adapter is really a classical adapter, using the famous MAX232 RS232-TTL levels converter. On the RS232 side, you get signals so:
1 = -7V to -12V
0 = +7V to +12V
On the TTL side, you get signals so:
1 = +5V
0 = 0V
(note that signals are inverted between sides).
The 4207Papy is the same version as their standard one, but including:
- the little jumper to bring power on PON9 off the sub-D, so it power-up the BT adapter
- spcial connectors for both power supply and TTL signals, so Claude's cable is easy to plug, without any risk inverting polarity
I also omitted to say that the Tronisoft module includes the 5V voltage regulator (Merlin output is from batteries, so from 9V to 12V).
You can use any design based on the MAX232 chip (there are plenty on the net, but non including the voltage regulator *and* a nice form factor).
Another solution is to use a BT-serial adapter which outputs TTL signals...
