#1 2009-01-21 17:39:00
Gordon
Merlin head, now configured with Tronisoft Bluetooth to Serial Adapter
My recently purchased Merlin head is now up and working with the Tronisoft Bluetooth to Serial Adapter, it appears to be doing what it's supposed to be doing... setting up the Bluetooth adapter was easy and the only difficulty I encountered was getting the cable tie tight enough enough on the board!!! I was too scared to give it a really strong yank, to avoid damaging the circuit board.
On powering up the merlin the Bluetooth to Serial Adapter lit up like a xmas tree, which confirmed that at least it was getting power, the real test came from powering up the N710 and waiting for it to boot up, setting papywizard to auto connect to the merlin was easy, well when I say easy, I mean it was a lot easier than setting up a Bluetooth earpiece and a lot quicker.
The real deal came when I inputed some coordinates via the N710 and saw it move first to the left, then to the right, then to the left, then to the right. then up then down then up again. I think you get the picture, it works smile  wonderfully.
The next step is to see about the crown etc. I'm thinking of using two DSLR's my Nikon D40 and possibly my Canon 350D.
I think for starters I'll be setting up my D40 with the 200m zoom first as it's  a smaller DSLR and appears to be easy to set the NPP.
Has anyone setup a D40 with 300m lens yet, what was your experience of setting up the camera to the unit? any pitfalls to avoid?
Gordon
2000th Member big_smile
GigaPixel Experimenter
#2 2009-01-21 17:54:33
ChrisLong
Re: Merlin head, now configured with Tronisoft Bluetooth to Serial Adapter
Well done Gordon!
How long did it take your Tronisoft kit to arrive?
#3 2009-01-21 17:56:36
bigwade
Congrats ! you have a working set ! Welcom to the club ! :-)
How many days it took you to get all the components ?
#4 2009-01-22 00:27:18
Gordon
The components for the Tronisoft Bluetooth to Serial Adapter took about 6 days to arrive and the cable another week so maybe 2.5 weeks in all, this was over the xmas period, the Merlin unit took about 3 days to arrive from ebay and included free postage from this seller http://cgi.ebay.co.uk/Acuter-Merlin-Alt … 240%3A1318
I understand that some of you are still waiting for your components to arrive, maybe it's lost in the post! or something has occurred with Tronisoft. I buy a lot of stuff online so I'd say 14 to 20 days for a delivery is ok, 6 days is like running on turbo...  I hope that your issues are resolved soon.
Thanks guys it's like being a member of an exclusive club now wink with a very large membership card. I wonder how many of us Papywizards there are now?
Gordon
#5 2009-01-22 01:12:10
Website
I think for starters I'll be setting up my D40 with the 300m zoom first as it's  a smaller DSLR and appears to be easy to set the NPP.
Gordon
Gordon,
I use a Nikon D40 on the Merlin.
The camera body is an almost perfect size to obtain a good NPP (this should also be the case with a Canon 350D) with the camera mounted in a portrait orientation.
The only reason you may wish to modify the standard dovetail mount (aka on this forum as the 'crown') to attach the camera in portait mode at NPP would be the size of the 'barrel' of some lenses, rather than the size of the camera body.
My 18-55mm kit zoom, Nikkor 10.5mm FE and Sigma 8mm FE all fit fine with camera/lens at NPP using just half the standard rail to mount the camera in portrait orientation and I can get a full vertical rotation. You need to remove the large knob from the camera screw on the rail though.
If you plan to shoot hi-res. landscape mosiac panos with your 300mm lens with nothing closer to the camera than about 100 feet then parallax will not be an issue, and it doesn't matter about setting the NPP, and I suggest you try mounting the camera/lens in landscape orientation on the full L-shaped dovetail rail (just as one might with a telescope).
#6 2009-01-22 07:57:04
Website
http://www.autopano.net/wiki/action/vie … s_feedback
but it is not up-to-date! Feel free to add yourself.
#7 2009-01-23 00:08:42
Gordon
mediavets,
Thanks for the advice. I'm going to set up the D40 1st, the lens I have decided to use is the ED 55-200mm. NNP is not an issue at the moment as most of the internal GigaPixel images I take I use the the GigaPan for those. I will certainly attempt to invoke the merlin unit also for internals once I decide which lens to use.
The removal of the large knob is the next challenge wink let's see how that goes. fma38 I've added myself to the list smile the wiki works fine wink
Gordon
#8 2009-01-23 00:39:14
Website
Gordon,
The 55-200mm seems to have the same diameter barrel as the 18-55mm kit zoom so with D40 should fit fine at NPP on the Merlin.
Ther is a detailed description elsewhere on the forum about how to remove the large knob - I guess you've found that?
If you find you need a longer rail - these are cheap and OK - I have one:
http://www.pulsar-optical.co.uk/prod/Sc … tailm.html
If you find internal batteries limiting try an external battery pack - I have one of these:
http://www.pulsar-optical.co.uk/prod/Sk … upply.html
#9 2009-01-23 02:54:06
Gordon
mediavets wrote:
Gordon,
Hi mediavets, thanks for all the pointers. Yes I have seen the knob removal post and am going to attempt that process later today! The rail looks good and I think I'm going to get one. Now as for the external batt pack, I was looking to make my own, but this seems to have it all, the only reason for making my own would have been the weight issue when travelling etc as lighter is better, I'm going to have to do a test run with rechargeable and see how many shots I can get out of them, then look at how to fire the camera possibly using gentleled of my own construction! if possible.
Gordon
#10 2009-01-23 21:58:43
Gordon
Well the large knob removal process was easy enough, what I did in the end was attach and secure the bolt to the camera, lock the swivel lock thing and tried to remove the screw without heat, the screw came out without too much trouble. the knob was now screwless!!! I applied heat to the metal middle of the knob taking care not to touch the plastic, it got pretty warm, I then inserted a blade between the knob and the swivel lock thing and applied some pressure, the large knob came away cleenly. Not too messy a job I think.
So now I'm left with a metal stub any ideas what I can attach to it?
Gordon
#11 2009-01-24 02:23:51
bigwade
I have found some hardwood at the DIY shop, same size as the Merlin rail :-)
A cabinetmaker around the corner did the edges and made one part 3mm less thick.
Now I can make several arms and drill holes where I want.
Total costs Eu 15,-  :-)
With the less thick part the 5D is in NP too. (with the original crown !)
I will make some more pictures later.
grtz!
Uploaded Images
#12 2009-01-24 10:12:22
Website
Nice!
#13 2009-01-24 11:46:19
Gordon
grtz!
It's good to see a return to classical traditional camera materials, after seeing what you have done, I'm considering using a small piece of oak that I have lying around, should be strong and stable enough.
Gordon
