#1 2008-12-24 07:26:19
irpano
Sugested Mods for Orion/Tronisoft module
smile Hi all. I hope all have an enjoyable Xmas break and Remain enthusiastic anoy Papy wizard and autopano .
Here is a suggestion for a way to keep the Tronisoft/BTLink module safe from damage when out in the field.
ClaudeH asked that I post this suggestion here. I Hope it will explain the method and be beneficial to all
http://dnirman.jalbum.net/Other/Orion%20Head%20Mods.pdf
#2 2008-12-24 09:38:27
Website
Re: Sugested Mods for Orion/Tronisoft module
Nicely documented - thanks for the tips.
The challenge is to find a plastic box the right size.
I've explored small plastic food containers - they have the advanatge of being made in semi transparent plastic, but haven't yet found one quite the right size,
I'm thinking I might use a spectacle case if I can find one the right size, because they have nicely hinged lids too.
http://www.optoplast.com/products-plastic-smarty.html
http://www.moltengold.com/cgi-bin/eBzge … s_case.htm
http://www.moltengold.com/cgi-bin/eBzge … s-case.htm
My idea for attaching the container to the head was rather cruder - some velcro tape attached to the outer casing of the vertical arm
#3 2008-12-24 10:23:24
Website
Great doc, irpano!
#4 2008-12-24 18:28:45
bigwade
briljant idea irpano.....
http://www.autopano.net/forum/t5025-ide … erter-case
You are the second :-)
#5 2008-12-25 00:46:29
claudevh
Website
Great Doc, John ! smile
We will post in the Wiki ...
This combined with the "Jellybean Case" of Andrew, we will be "in the mood ...!" lol
cool
cool Claude cool
#6 2008-12-26 20:43:01
bigwade
My original idea was to use the JVC box:
but I asked some friends and got a Kenwood radio-front box.
It's smaller,  you don't need bridges for the module, just leave some original foam.
The idea is to mount it on the backside of the batterycap ( just sprayed it black) with Velcrotape.
No complicated constructions, no need to see the leds, the Nokia 770 connects automaticly smile
Photo's later........
#7 2008-12-27 00:01:14
irpano
I had built a box out of  cardboard and coated it with 2 part epoxy finish to increase its strength, when I noticed your suggestion about the JVC Box. I always like things that are solid and easily replaced, especially when you attempt projects that no one you know has any ideas about it. Down here in Oz , even the importer of the head did not know how it worked and any conversation with them is more like you telling them. So as I continue to work with the Orion/Tronisoft/Papywizard/windows Eee solution, I keep coming up with different solutions. I see the whole assembly as a stand alone solution and I want to have a reliable,stable and robust solution. Thats why I went with this package. To me being able to sit in a pleasant spot beside my tripod  and capture a panorama of the scene without having any equipment worries is what its all about.
#8 2008-12-27 01:50:21
bigwade
smile
Uploaded Images
#9 2008-12-27 01:57:27
Website
So where do you buy these radio-front boxes?
This is all I could find on eBay:
http://cgi.ebay.co.uk/Universal-Car-Ste … 240%3A1318
#10 2008-12-27 02:10:42
bigwade
Just ask your friends......
They might have dozens of them.
I never used mine and I have the JVC box here and you may have it.
Just mail me.
But if you can get a Kenwood box, go for it smile
#11 2008-12-27 23:15:51
irpano
Hi all. Further on the subject of a case for the Tronisoft module. I found that if you visit your local electrical materials supplier you can buy square plastic cable duct 45 X 25 that has end caps as well. Should be only a matter of cutting the correct length and glueing in the end caps. Top piece clips on with little pressure. Might be worth a try for those who cant find a suitable plastic box.
#12 2008-12-28 01:44:43
Website
irpano,
Thanks for that idea.
