#1 2008-12-21 18:36:12
Paul
Resistor problem
First:
I am totally stupid on electronics
Second:
Papywizrd / Merlin runs fine when connected with a 2m cable with 2 220Ohm resistors at the BT-Module end
Third:
Papywizard / Merlin does connect but then neverending miniwindow "Please wait" when connected with a 20cm cable with 2 220Ohm resistors at the BT-Module end
Fourth:
What is going wrong? I quadruple checked the correct wiring.
Paul
#2 2008-12-21 18:45:38
Website
Re: Resistor problem
What you are saying is that it works fine with a 2m cable, and fails with a 20cm one? With exactly the same config?
Which plateform?
#3 2008-12-21 18:54:13
Paul
yes exactly the same components: on long cable OK, on short cable connect and neverending wait
platforms tested:
- WinXP SP3 Papywizard 1.4.0
- N770 Papywizard last dev. version
Paul
#4 2008-12-21 19:21:01
Website
And it freezes on both plateforms? No error message after a few seconds?
On the Nokia, try to launch papywizard from the console (osso-xterm):
$ papywizard.sh
You should see the log on the console...
#5 2008-12-21 23:18:52
Paul
Thats is the log connected to the short cable - BT-Module shows connect LED
BusyBox v1.4.1 (2007-03-12 19:00:25 EET) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
~ $ papywizard.sh
2008-12-21 23:08:54,220::MainThread::DEBUG::Papywizard.l10n(): default locale=de_DE
2008-12-21 23:08:54,268::MainThread::DEBUG::Papywizard.l10n(): LANGUAGE=None
2008-12-21 23:08:54,280::MainThread::DEBUG::Papywizard.l10n(): langs=['de_DE', 'en_US', 'fr_FR', 'pl_PL']
2008-12-21 23:08:54,395::MainThread::DEBUG::Papywizard.l10n(): localeDir=/usr/share/locale/de/LC_MESSAGES/../..
2008-12-21 23:08:54,982::MainThread::INFO::Starting Papywizard...
2008-12-21 23:08:55,104::MainThread::INFO::Loading default presets
2008-12-21 23:08:55,522::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2008-12-21 23:08:55,636::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2008-12-21 23:08:55,655::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2008-12-21 23:08:55,869::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2008-12-21 23:08:55,983::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2008-12-21 23:08:56,121::MainThread::INFO::Loading user presets
2008-12-21 23:08:56,133::MainThread::WARNING::No user presets found
2008-12-21 23:08:56,330::MainThread::DEBUG::Spy.__init__(): yaw=0.0, pitch=0.0
2008-12-21 23:08:59,405::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['1', '5', '3'], user=['1', '5', '3']
2008-12-21 23:08:59,418::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2008-12-21 23:08:59,845::Spy::INFO::Starting Spy...
2008-12-21 23:08:59,858::Publisher::INFO::Starting Publisher...
2008-12-21 23:09:08,093::MainThread::INFO::Connecting to real hardware...
2008-12-21 23:09:18,881::Dummy-5::EXCEPTION::Axis._sendCmd
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/axis.py", line 235, in _sendCmd
    answer = self.__driver.sendCmd(cmd)
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/bluetoothDriver.py", line 122, in sendCmd
    c = self._sock.recv(1)
  File "<string>", line 5, in recv
BluetoothError: timed out
2008-12-21 23:09:18,896::Dummy-5::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2008-12-21 23:09:20,234::Dummy-5::EXCEPTION::Axis._sendCmd
2008-12-21 23:09:20,248::Dummy-5::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2008-12-21 23:09:21,421::Dummy-5::EXCEPTION::Axis._sendCmd
2008-12-21 23:09:21,435::Dummy-5::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2008-12-21 23:09:21,799::Dummy-5::EXCEPTION::Shooting.switchToRealHardware()
  File "/usr/lib/python2.5/site-packages/papywizard/model/shooting.py", line 282, in switchToRealHardware
    self.realHardware.init()
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/head.py", line 93, in init
    self.yawAxis.init()
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/axis.py", line 251, in init
    self._sendCmd("L")
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/axis.py", line 242, in _sendCmd
    raise HardwareError("Axis %d can't send command" % self._num)
HardwareError: Axis 1 can't send command
2008-12-21 23:09:21,822::MainThread::ERROR::Can't connect to hardware
2008-12-21 23:09:27,173::MainThread::INFO::Go to simulation mode
2008-12-21 23:09:28,368::MainThread::EXCEPTION::Axis._sendCmd
2008-12-21 23:09:28,379::MainThread::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2008-12-21 23:09:29,701::MainThread::EXCEPTION::Axis._sendCmd
2008-12-21 23:09:29,717::MainThread::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2008-12-21 23:09:30,905::MainThread::EXCEPTION::Axis._sendCmd
2008-12-21 23:09:30,918::MainThread::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2008-12-21 23:09:30,944::MainThread::EXCEPTION::Shooting.switchToSimulatedHardware()
  File "/usr/lib/python2.5/site-packages/papywizard/model/shooting.py", line 295, in switchToSimulatedHardware
    self.realHardware.shutdown() # Test if init first
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/head.py", line 109, in shutdown
    self.yawAxis.stop()
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/axis.py", line 371, in stop
    self._sendCmd("L")
Thats is the log connected to the long cable
~ $ papywizard.sh
2008-12-21 23:18:32,017::MainThread::DEBUG::Papywizard.l10n(): default locale=de_DE
2008-12-21 23:18:32,065::MainThread::DEBUG::Papywizard.l10n(): LANGUAGE=None
2008-12-21 23:18:32,076::MainThread::DEBUG::Papywizard.l10n(): langs=['de_DE', 'en_US', 'fr_FR', 'pl_PL']
2008-12-21 23:18:32,169::MainThread::DEBUG::Papywizard.l10n(): localeDir=/usr/share/locale/de/LC_MESSAGES/../..
2008-12-21 23:18:32,788::MainThread::INFO::Starting Papywizard...
2008-12-21 23:18:32,928::MainThread::INFO::Loading default presets
2008-12-21 23:18:33,353::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2008-12-21 23:18:33,472::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2008-12-21 23:18:33,592::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2008-12-21 23:18:33,713::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2008-12-21 23:18:33,827::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2008-12-21 23:18:33,964::MainThread::INFO::Loading user presets
2008-12-21 23:18:33,976::MainThread::WARNING::No user presets found
2008-12-21 23:18:34,085::MainThread::DEBUG::Spy.__init__(): yaw=0.0, pitch=0.0
2008-12-21 23:18:37,346::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['1', '5', '3'], user=['1', '5', '3']
2008-12-21 23:18:37,357::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2008-12-21 23:18:37,792::Spy::INFO::Starting Spy...
2008-12-21 23:18:37,959::Publisher::INFO::Starting Publisher...
2008-12-21 23:18:48,839::MainThread::INFO::Connecting to real hardware...
2008-12-21 23:19:01,770::MainThread::INFO::Now connected to real hardware
2008-12-21 23:19:31,829::MainThread::INFO::Set hardware originSegmentation fault
Trying to quit Papywizard crashes with segmentation fault
Paul
#6 2008-12-21 23:55:06
Website
Short cable: Bluetooth connection is OK; the problem occurs when Papywizard try to get the answer from the Merlin head... It is either because the command never reached the head, or because the answer can't reach Papywizard. Could you try this:
http://www.autopano.net/forum/p33669-20 … -01#p33669
Long cable: seg. fault is never good, especially with python as something occured in a C library (which I don't have any control on)... Does it works fine when launched from maemo menus, and only crashes when started from shell? Well, in fact, if it crashes when you quit, you may don't see the problem, as the program exits in any case...
#7 2008-12-26 23:21:54
claudevh
Website
Hi Paul,
Long/short cable  ...
Is you problem solved now ?
cool
cool Claude cool
#8 2008-12-28 12:16:49
Paul
claudevh wrote:
Hi Paul,
cool
only partly solved:
BT works fine with short cable when I plugin the Handcontroller too
without HC BT does connect, but PW shows neverending the little "please wait"-window
Paul
