#1 2008-12-11 05:16:34
irpano
Making cable from Head to Canon 30D
Hi again,
Just got some equipment for putting together the cable from the Head to a Canon 30D camera.
I've read the other post about how to cut the remote cable and wire the jack plug to the end the Canon cable. The only problem is that i have 3 coloured wires and two connections on the jack plug. Not wanting to blow up my camera I'm hesitant to proceed without making the correct connections.
Out of the Canon remote lead there are 1 x yellow, 1 X red and 1 X white leads. Can anyone supply the wiring for each of the wires to the jack plug.
#2 2008-12-11 07:43:25
Website
Re: Making cable from Head to Canon 30D
Don't worry, you can't blow up anything. There is one common, and 2 contacts (1 for AF cycle, 1 for shutter cycle). Just try to figure out which is which smile
To use with the Merlin, you will have the AF and shuter contact wired together, so when the Merlin close its contact, both cycles are triggered, like if you push the camera button without waiting half way.
#3 2008-12-14 04:36:13
irpano
Thanks for the reply, I've got the cable working and found that the white is commo0n and the red and yellow should be wired together.
#4 2008-12-14 08:35:32
Website
Yes, you should be right (I've rewired my manual remote control for my 20D, yesterday, and I think it was the same colors).
#5 2009-01-03 17:49:27
mark_anderson_us
Website
irpano wrote:
Hi again,
Hi irpano
I have a 30D and am considering buying the merlin head and rest of kit. Before I do I'd like to find out more about the NPP alignment for 30D, as I will be doing mostly cityscapes with a lot of close objects, so I need the NPP set correctly.
Did you make any adjustments to get the NPP precisely aligned?
What lenses do you use with it. I only have L-series f/2.8 lenses (16-35mm f2.8L, 28-70mm f2.8L) and would prefer to use these. Do you by chance have either of these?
regards
Mark
Canon EOS 30D with BG-E2 grip
50mm f1.4, 16-35mm f2.8L, 28-70mm f2.8L, 70-200mm f2.8L, 100mm f2.8 Macro
Gitzo 2531, Merlin/Orion
#6 2009-01-03 17:53:22
Website
Mark,
Do you plan to shoot sphericals or partial panos (less than 360x180)?
Typically, how close are your 'close objects' in a cityscape?
This post provides the information that will help you determine whether you can set your Canon 30D on the Merlin head at correct NPP without modifying the 'crown' (rail mount) on the head.
http://www.autopano.net/forum/p32910-20 … -34#p32910
The size of your camera body and lens will also determine the max. positive pitch (upwards tilt) you will be able to achieve without the camera body hitting the Merlin head.
#7 2009-01-03 18:21:44
mark_anderson_us
Website
Hi Mediavets
Thanks for the reply. I'll be doing partials (say 180 x 120) and full 360 x 120-180 panos. I can live without the full vertical tilt as I don't find pictures of the sky too appealing :-). That said, where space is tight, I may need to get almost vertical to get in the tops of tall buildings.
regards
Mark
#8 2009-01-03 18:39:39
Website
Mark,
If you are using a manual pano head now what are the upper rail settings for NPP with your to lenses - from centre of upper rotator to tripod screw socket on camera?
Max. vertical clearance between centre of vertical rotator to battery compartment cover of Merlin/Orion head is about 125mm.
So you can probably figure out the max. vertical pitch you will be able to achieve with your lenses on the Canon 30D with the Merlin/Orion head.
You certainly won't be able to achieve NPP with the battery grip attached to the Canon 30D with standard 'crown' (rail mount).
#9 2009-01-03 19:28:47
claudevh
Website
Hi Mark,
A summary of the adaptation problematic is found herafter:
http://www.autopano.fr/wiki/action/view … 27appareil
And a PDF document herafter:
http://upload.wikimedia.org/wikipedia/c … be_pub.pdf
cool
cool Claude cool
#10 2009-01-03 19:52:39
Website
Mark,
The Canon 30D body will mount at NPP without modification of rail mount of the Merli/Orion head BUT those lenses of yours are quite large - it may be that the diameter of the barrels of these lenses prevents the camera/lens combo being mounted at NPP without modification of the head.
#11 2009-01-03 23:39:34
bigwade
Mark
Hi Mark
The 30D alignment is about oké.
Your 50mm will work and a 17-85 allso without crown modification.
The bigger L-Lenses won't fit the body without crown-modification.
BTW made a 140x80 degr with a 450D with a 17-85mm @50mm and the result was good. (about 2,2 gig rect. but it has to be cropped because the left and right are stretched too much and the reflections of the windows)
84 shots..through dubble glass
Not a great view IMO but client want's it.....
About cable: buy a cheap 30D/5D remote on eBay and you can use the suplied Merlin Cable.
The eBay one has a minijack female, the Merlin is male on both sides
Uploaded Images
#12 2009-01-08 23:45:16
mark_anderson_us
Website
Can anyone recommend a brand/seller on ebay. I've looked at dozens and don't see any with a minijack female
#13 2009-01-08 23:58:04
Website
Try CALUMET. I bought a female-->Canon 20D adapter which i use with Merlin/Orion´s male-->male cable.
It´s part of a cheap asian radio-remote release they sell - at least here in Germany.
#14 2009-01-09 00:14:22
mark_anderson_us
Website
thanks klaus.
what was the adapter for? was it 60E3 to 20D?
Would it be equivalent to this:
http://www.amazon.com/Canon-Remote-Swit … B00009R6VV
Regards
#15 2009-01-09 00:23:08
claudevh
Website
Mark,
I have buy this one recently:
http://cgi.befr.ebay.be/Remote-Cord-Shu … dZViewItem
cool
Uploaded Images
cool Claude cool
#16 2009-01-09 00:29:45
bigwade
That's the one I have too, no problems :-)
#17 2009-01-09 00:40:52
mark_anderson_us
Website
Thanks guys
One problem: can't find in US!
It's available in UK and I have a colleague coming over to US in a few weeks, so I may get him to buy one for me and bring over
Regards
mark
#18 2009-01-09 00:45:57
bigwade
eBay !!!!!!!!!! just order.
it will be shipped to your front door......
And if this one does not, another will.......
What's the problem ?, just curious smile
#19 2009-01-09 00:47:29
Website
thanks klaus.
Regards
looked somehow alike - but i paid 9.-€ . . .
http://www.calumetphoto.de/item/CALCF0061/
http://www.calumetphoto.com/item/CF0061/
#20 2009-01-09 00:50:26
bigwade
http://tinyurl.com/7a3bnq
or just type "Remote-Cord-Shutter-for-Canon-EOS-5D-30D-40D-RS-80N3" in the search of eBay.......
5-15 euro and that's it.......
EDIT
Oeps Klaus, that's a more interesting cable.....
#21 2009-01-09 01:14:43
claudevh
Website
Mark,
They ship to US ... ! big_smile
You can also order directly to the shop :
http://www.enjoyyourcamera.com/Fernausloeser:::3.html
cool
cool Claude cool
#22 2009-01-09 11:49:37
Website
claudevh wrote:
Mark,
cool
I bought one from them last year - the jack in the handpiece didn´t work . . .
on a second one it sometimes worked, sometimes didn´t . . and it´s too long for that purpose.
I bought a Canon original after that. But it has no jack for the Merlin´s connection in the handpiece.
Regarding the price and the fact, that Calumet has 10 stores in the US i strongly would suggest the Calumet thing. It´s smaller than the other one and you don´t need a long cable with handpiece for that purpose. In combination with the Merlin´s own cable it´s long enough even for 600mm lenses on the Merlin/Orion (if you would put one on it . . wink )
#23 2009-01-09 11:58:14
Website
Sounds ideal - a much neater solution.
#24 2009-01-09 15:35:51
mark_anderson_us
Website
Thanks Guys. Found one finally!
