#1 2008-09-12 05:27:14
javaduke
Problem with HDR
Sorry if this is an FAQ but I couldn't find much information on this forum or in the docs.
I have a number of bracketed exposures with EV -1, 0 and +1. The preview looks ok, but when I select HDR color correction and then open Tone Mapping RH4 dialog and select Enabled, the preview becomes just a black rectangle - is it normal? If I select LDR color correction, it renders ok but highlights become overexposed.
Thank you!
JD.
#2 2008-09-12 07:45:33
Website
Re: Problem with HDR
You have to adjust the Tone Mapper sliders to get the correct exposure...
#3 2008-09-12 14:24:20
javaduke
Nope, it doesn't work. If I move both sliders all the way to the left, I see some details but the image is still very dark.
#4 2008-09-12 17:06:17
Website
Did you use anchors?
#5 2008-09-24 13:54:28
360 Degree
Thank you!
JD.
I think you'll be a lot happier with overall results if you tone map first with Photomatix Pro. Then stitch with APP.
Sy
#6 2008-09-25 17:22:52
Tom13
I Agree, there is a bug... I can make it work when the color correction is on none instead of HDR... But the filter are not convenient to use anyway. I really love Autopano... But for HDR, PTGui is better... Let's cross finger that next version will have better HDR function
#7 2008-09-30 17:47:12
360 Degree
I agree, PTGUi does a better job with HDR than APP. However, overall, APP is without comparison. But for HDR, nothing better than Photomatix Pro.
#8 2008-09-30 18:02:47
DrSlony
Website
Don't confuse HDR with tonemapping.
APP-2 is planned to have better tonemapping and exposure fusion.
