#1 2008-08-25 15:34:44
karlo
Panorama of Long Wall - Problem Stitching
HI there!
I have problems stitching a panorama of a long wall. As you can see in the first picture below the beginning and the end are stitched together - although they don't have anything to do with each other (2. picture).
I also posted the prefs below.
Here is the link to the picture set: http://uploaded.to/?id=2mb2xz
Did it with a Canon Eos 350d and the standard lens.
Distance about 3-4 meters (9-12 foot)
Hope someone can help me wink
http://img124.imageshack.us/img124/8430/hall1xo9.th.jpg
http://img391.imageshack.us/img391/6987/hall2kb3.th.jpg
http://img258.imageshack.us/img258/3185/hallprefqq7.th.jpg
http://img246.imageshack.us/img246/3806/hallpref2ps5.th.jpg
#2 2008-08-25 15:50:48
Website
Re: Panorama of Long Wall - Problem Stitching
???? a bit more of information would possibly be helpful . . . . cool
Which lens, camera, setup, shooting, distance - which focal-length in the lens-prefs. Why using "adjust lens distortion"?
Does your lens produce any?
#3 2008-08-25 16:23:27
[bo]
community overseer
Use the Control Points editor and remove the link between the first and last image. Then Optimize and after that - use the Center Point tool to set a center point for the pano.
http://www.autopano.net/wiki/action/vie … nts_Editor
http://www.autopano.net/wiki/action/vie … nter_Point
#4 2008-08-25 19:49:02
karlo
I solved it partly:
nothing was wrong with my config. Reducing the image-count did it.
There seems to be a limitation in the Aspect-Ratio of the panoramas - so you can't make VERY wide panoramas - at a specific width the panorama overlaps (as seen in my picture above).
Is this a bug or is there a setting somewhere to fix this problem? Hane not found anything
Karlo
#5 2008-08-25 22:00:17
marco-pano
Website
karlo wrote:
... Reducing the image-count did it.
I'm not sure to understand what you mean by "reducing..."
karlo wrote:
... There seems to be a limitation in the Aspect-Ratio of the panoramas - so you can't make VERY wide panoramas...
Maybe you are right. I never try APP doing a larger panorama than 360x180° lol Probably some trick can do it.
Marco, Paris wink
#6 2008-08-25 22:13:52
karlo
=> I made the panorama out of less pictures
#7 2008-08-25 22:53:02
marco-pano
Website
Dear Karlo, you are a new member, may be new to panorama first.
When you like to post pictures, we genererally prefer that members use the upload integrated in this forum than sending us to outside servers that always add some stupid "Ads"or "PopUp". Thank you.
You said having taken a "panorama" which is basically taking pictures around a center point, and user spend money for a good tripod and pano head to make sure the pictures are taken around the NPP (Non Parallax Point) of the lens.
Seeing your pictures, I guess that you just walk along a wall, taking handheld pictures, not always at same distance from the wall, not always perfectly perpendicular to the wall. This is not panorama but "orthophoto" or "like scanning".
To do this, you should stay always at same distance from the wall and take pictures perpendicular to it (just think that you are a scanner lol ).
After loading your set of pictures in the detection group, click on "images properties" button. In the "Settings" window, write 1000 in the control under "Focal (35mm eq.)
Click on the "Open settings" button, make sure "Adjust lens distortion" and "Advanced distortion"checkbox are unchecked.
Then you can launch the detection. You should have better result.
Before thinking that a software may have bugs, please, please, make sure you use it in the rigth way.
Uploaded Images
Marco, Paris wink
#8 2008-08-25 23:09:38
DamoRed
I haven't attempted stitching the wall yet, but may I suggest to you to shoot from left to right in future, as it makes sequencing images a a whole lot easier. Less stress on the brain! lol
Okay, I made one attempt, and I got what has become known as an Alexandroid big_smile
Damo
Uploaded Images
Go sell crazy some place else... we're all stocked up here!
#9 2008-08-25 23:39:56
marco-pano
Website
Hi DamoRed, your pano is much more beautiful than my stitching lol nice Alexandroid !
Could you check that you don't have too many links between "far" neighbourghs, I mean pict#1 -> pict#2, pict#2 -> pict#3, but also pict #1 -> pict #3. This one may be of weak quality and lead to heavy contrains in the panorama, just try to delete too far links.
Of course, don't delete this *.pano file, somebody may be interested smile
Marco, Paris wink
#10 2008-08-26 00:02:04
DamoRed
With apologies to Pink Floyd...    and Karlo! tongue
Karlo needs some education,
Panos need some point control,
The forum here will be your classroom
you cannot work handheld alone.
Use... tripod, leave handheld alone!
Now you go and get... another pic of the wall
Bring a tripod and get another pic of the wall
Okay, okay, I know that working handheld is possible, I've done it myself. But the conditions must be right, it doesn't work all the time. Just consider it artistic licence for now! cool
Damo
#11 2008-08-26 06:53:52
leedsjoe
Damo
This concerns 'stress on the brain' One reason for that stress is the order in which images are displayed in the Control Point Editor  At http://www.autopano.net/wiki/action/vie … nts_Editor and 'Add Control Points' the documentation makes the point that you can display images in the reverse order by re-sorting on the image number [#] column
#12 2008-08-26 09:16:55
Website
lol
#13 2008-08-26 12:41:49
Website
Karlo
marco-pano wrote:
Dear Karlo,
marco-pano is quite right. I got an excellent stitch of your image set following his advice. View it as a Flash pano:
http://www.three60views.org.uk/graffiti … ti_02.html
You might also find it interesting to try Photosynth with this sort of image set?:
http://livelabs.com/photosynth/
It's Windows only at the moment but wider platform support promised.
This is the sort of result you get:
http://photosynth.net/view.aspx?cid=57C … 7D47A34D60
There's not sufficient overlap between images - Photosynth 'likes' about 50% - to link all the images together but it has linked several subsets and left some orphans. Photosynth does quite well with these orthographic images sets.
It is a far from conventional 'stitcher' but has many interesting features and characteristics.
#14 2008-08-26 13:03:22
DrSlony
Website
DamoRed big_smile
#15 2008-08-26 13:06:38
DrSlony
Website
This is what they wrote before their website crashed my browser:
"Unfortunately, we're not cool enough to run on your OS yet. We really wish we had a version of Photosynth that worked cross platform, but for now it only runs on Windows. Trust us, as soon as we have a Mac version ready, it will be up and available on our site."
So I appear to be running Macintux! big_smile
#16 2008-08-31 15:06:58
Website
Like Sugimoto does the "double-infinity" you can surely do a "double-360" . . . tonguecool
#17 2008-08-31 19:58:58
marco-pano
Website
klausesser wrote:
... Like Sugimoto does the "double-infinity" you can surely do a "double-360" . . . tonguecool .best, Klaus
Sorry, link to this picture is some where in my many CDs. This one is 3 x 360°. Enjoy lol
Uploaded Images
Marco, Paris wink
#18 2008-09-01 00:20:41
Website
great work, Marco-San . . cool
#19 2008-09-01 01:46:11
mgg310
Sorry to be a bit dim, but what exactly is a 3 x 360 degree panorama?
Mike.
Panasonic DMC-G1. 14-45 (28-90 35mm equiv); 45-200 (90-400 35mm equiv); Panosaurus.
#20 2008-09-01 08:44:43
Paul
I asked me that same question.
Until I looked to the different scenes on the same spots second and third roundtrip.
Cheers
Paul
Paul
#21 2008-09-01 08:47:54
marco-pano
Website
Yes, a great work but unfortunately I don't have the author name. This is a 3x360° : look the picture you can see 3 times the same trees but different people in front cool
Marco, Paris wink
#22 2008-09-01 10:13:35
mgg310
Hmm! Bit dim not quite strong enough!
Mike.
#23 2008-09-05 23:51:40
OfF3nSiV3
That's is too awesome!
How did you do that? I need to know!
edit: hum did you swap people between shots?
#24 2008-09-06 00:35:50
phototrek
Website
I think two key ingredients: patience and coordination with cooperative subjects smile
iMac 27"
Canon Equipment
#25 2008-09-06 00:52:17
DamoRed
Marco, I love that idea. I'm thinking about trying it for a friend's wedding in a couple of weeks. First condition, if the weather is fine and suitable.. and if I can get everyone away from the bar long enough!
Just thinking about the headache it will be to organise it... 'ok, you're done, scoot...now, Sir & Madam, can you please take that spot and don't move until I come around again'.
1080º later.. "I'm dizzy, somebody get me a drink" tongue
I'm not the main photographer, (And they're not getting a wedding album anyway) so I can spend a little time on it without worrying about the 'money shots'. It may be a case where I can only get the Bridal Party and a few family and do one rotation. If so, then that's okay too, I can then close it at that and they've got a rather different image and a movie for their website.
I've photographed weddings on my own a number of times and I know how time can disappear so easily. Doing something different like this would definitely not have been possible, even if I'd known about panoramics then.
Damo
