| User list | Rules | You are not logged in.
I am wonedring whther one could adapt industrial window cleaning poles for use as pano poles.
This sort of thing:
http://windowcleaningsupplies.net/cata_show.asp?id=25
The only issue seems (to me) to be how to attach a camera head to the top of the pole.
But this article shows it can be done to make a low cost mic boom:
http://www.videobusinessadvisor.com/bui … _boom.html
Anyone tried it for pano pole?
This sort of thing:
from Manfrotto you can get a 2-piece alloy pole of app. 2,75m - designed for backdrop-paper-rolls.
Light (1,3Kg) and very sturdy - is stacked by expandable cores of massive alloy at the junctions.
http://www.bogenimaging.de/Jahia/site/b … randId=MAN
The same product is available fitted with a holder for camera-srews on one end.
I used a telescope lighting-monopole of app. 3,50 length holding it 45deg in 3m above the reiling having put a camera on it´s top using the lamphead-screw for pano down from the Messeturm in Frankfurt: http://www.klausesser.de/mtower.mov
I was not able to find any reference to the holder on the Bogen web site.
It's a great pano.
What brand of pole did you use? Do you have an image of the setup at the camera end?
Hi Andrew!
The Manfrotto-site is one of the worst-made sites i know . .
In fact the link is exactly what i mean - but they only show the junctions and not the full length of the pole.
Here are some handyshots - i´ll make some more informative ones . . ![]()
p.s.: the telescope boom is a Balcar monopole and about 3,50m long. I used that configuration for the pano - but in a diagonal position.
The black pole is the one i described earlier - all parts are from Manfrotto. And as a coicidence a 20D with a Nikon 10,5mm happens to match the NPP perfect when mounted at the "knee".
The black boom is about 2,70, long and comes in two halfs. It´s exandable too three sections by stacking one more - but then i would put a tube over the junctions to stabilize them.
As a two-piece pole it´s very rigid and bears the camera without problems - vibrations are very low!
Thanks for images Klaus.
Here is another pole system - not exactly inexpensive but appears to be quite well thought out:
Focalpoint (http://www.focalpoint2000.co.uk/)
Hi Andrew!
Yes - not bad. But a bit expensive for toying around ![]()
COMMUNITY Forums YouTube channel Google+ |
COMPANY Blog About Kolor Resellers Contact Visit us |
