#1 2013-02-28 15:19:24
QuintusJ
Hotspot Objekt Close outside
is it possible to close a Hotspotobjekt outside the Objekt. With the default setup it closed only when you cklick on the Objekt "onclick="closespot0object();"". But I want to close the Objekt when you Click outside(on the Pano).
Thank you for help
#2 2013-02-28 15:56:48
Website
Re: Hotspot Objekt Close outside
QuintusJ wrote:
Thank you for help
Where would the pano know which object you mean if you´re not clicking ON the object? winkcool
#3 2013-02-28 16:13:10
QuintusJ
it is possible when cloe all objects.
#4 2013-02-28 17:17:38
Website
No good idea! cool - or would you always like to close all objects when you want to close only one?
Maybe you better be a bit more precise about what you really want to do. Do you ALWAYS have
only ONE hotspot in the scene?
What´s the problem clicking ON the spot?
#5 2013-02-28 19:07:50
Website
QuintusJ wrote:
Thank you for help
Let me see if I understand your question.
You have a hotspot linked to display an image when you click on the hotspot? - is that correct?
And you wish to be able to close the image by clicking not on the image but elsewhere on the underlying pano image - is that correct?
