#1 2013-02-21 11:32:24
christa
Sound Delayed
When moving from panorama to panorama in a published tour there's a delay in the sound/music coming off and on. How can I avoid this? Any advice greatly appreciated.
Maria
#2 2013-02-21 11:45:28
Website
Re: Sound Delayed
How large are your sound files?
Are they directional/spot sounds aor scene background sounds or both?
#3 2013-02-21 13:50:34
christa
Re: Sound Delayed
Thank you very much for getting back to me. Too large probably. 6-8 MB. Background music. What's the optimal size for sound (minimum/maximum bit rate) and video? Another question on the subject of sound if I may. When clicking on a spot sound, like a talking book in a book store for instance, it doesn't cut out the background sound. However it works the other way so is there a way to make it work both ways.
Apologies for taking advantage of you replying/helping in the first instance.
Thank you.
#4 2013-03-03 14:53:16
hotline
Re: Sound Delayed
You need to "force" to play the sound immediately AFTER your xml file is complete loaded !
Here is the code to change:
    <!-- actions to perform while loading -->
    <events onloadcomplete="onloadcompleteaction();"/>
    <action name="onloadcompleteaction">
        if(plugin[data].soundOn==false,stoppanosounds(),playpanosounds());
    </action>
    <action name="playpanosounds">
         playbackgroundsound(%BASEDIR%indexdata/sounds/sound0.mp3,0,%1);
    </action>
    <action name="stoppanosounds">
         stopbackgroundsound();
    </action>
_____________  new code __________________________________________
    <events onxmlcomplete="onxmlcompleteaction();"/>
    <action name=" onxmlcompleteaction">
        if(plugin[data].soundOn==true,stoppanosounds(),playpanosounds());
    </action>
    </action>
    </action>
Nikon D800E Nikkor 16mm f2.8 ; Nikon D700 Nikkor 70~200mm f2.8 VR2 Nano; TC20E III; trépieds Benro carbon ; tête panosaurus ; autopano giga 64bits 3.0.5 ; panotour pro v1.8.0 64 bits
#5 2013-03-03 15:37:21
Website
Re: Sound Delayed
hotline wrote:
You need to "force" to play de sound immediately AFTER your xml file is complete loaded !
Thanks for the tip.
I wonder why Kolor doesn't generate that code by default?
#6 2013-03-05 15:30:01
christa
Re: Sound Delayed
Thank you so much 'hotline' (sorry I don't know your name) for your help. Very kind. I suppose there's no way one can control the background music fading in and out? At the moment when changing from panorama and if varying the background music there's a very abrupt end to the music playing. I might be complicating things but it would be nice :-)
Christa
#7 2013-03-05 15:38:13
hotline
Re: Sound Delayed
Christa,
You know that it is easy to fade in / out with a lot of sound editor ?!
Michel
#8 2013-03-12 16:51:53
christa
Re: Sound Delayed
Sorry to be slow in saying thank you for your help hotline.
Christa
