  • Index
  •  » Hardware
  •  » Cutting up a large file to smaller parts. How can I do that fast?
#1 2013-02-13 10:56:43
aram23
I need to do the opposite action of stitching. I have a large file (PS max of 300.000 x 300.000 pixels) and need to cut it up in 4000 smaller square files. Unfortunately, not all the sizes are the same, some rows of smaller files need to be narrower than most. Is there a method to do this without manually placing grid lines in photoshop and cutting out the desired pixels, paste them in a new PS file, and save them as JPG?
All advice is welcome. I have a lot of photoshop experience, but never had to work with these super large .psb files.
Thanks,
Aram 23
#2 2013-02-13 11:04:35
Website
Re: Cutting up a large file to smaller parts. How can I do that fast?
Welcome to the forum...
This may be relevant?:
http://www.bigmike.it/kroutils/
#3 2013-02-13 12:28:41
Website
Hi..
Do you own Photoshop...??
aram23 wrote:
Thanks,
Aram 23
#4 2013-02-13 13:25:55
Website
Thanks,
Aram 23
Guess you can build a Photoshop-action to automate the thing.
But i think Andrews suggestion using KRO utils should be fine.
#5 2013-02-13 13:35:24
Website
Hi.. I have created a Droplet for you but you will need Photoshop.. I have sent it to you..
All you need to do is drag and drop your images onto the Droplet and it will create a folder and slice up your images in seconds..
  • Index
  •  » Hardware
