#1 2013-02-07 13:38:33
grzesczwa
I have a problem Mask edition
Hello
I have a problem.
I downloaded and installed a trial version of the software Autopano 3.0.3.
Loads up to 13 photographs of the room.
The program generates the skyline.
http://panoramaczestochowy.pl/strony/autopano/wer1.jpg
Then I turn 90 in the panorama of the level.
And with Mask edition panorama gain so as to
http://panoramaczestochowy.pl/strony/autopano/wer2.jpg
Then again odwrcam 90 degrees, and unfortunately the program does not remove the head NN5.
http://panoramaczestochowy.pl/strony/autopano/wer3.jpg
What am I doing badly
Regards
Gregory
#2 2013-02-07 19:00:46
Website
Re: I have a problem Mask edition
did you repress the "Preview" button after the pano shifted back (last screenshot)?
it is not needed to shift the pano to start with the masking tool. I generally do not do it. I just set my red points (the left one if no imagestacks used)...
(dont think its an demo restriction? or?)
#3 2013-02-08 08:52:08
grzesczwa
Problem solved I added more red points
#4 2013-02-08 20:51:16
HansKeesom
Website
They are magic aren't they, just mark the tripod wherever you still see it in the preview.
Regards,  Hans Keesom
I stitch and render for other photographers see http://tinyurl.com/brxvlhg for details
#5 2013-02-08 22:22:28
Website
yea but keep in mind while shooting... that the mask tool only can do the magic in the overlapping zone of images. So if in doubt just take one more image from same imageposition...
#6 2013-02-19 19:07:22
acf-fotografia
Website
i don't know how to use the masking tool in APG 3.0 to erase the tripod from my panos.
Where can i find some information about?
thank's
#7 2013-02-19 20:34:00
Website
acf-fotografia wrote:
thank's
Did you shoot an additional Nadir-image? If not the masking will be of no big help . . wink
You need something to fill the place the mask works on!
#8 2013-02-19 21:17:49
HansKeesom
Website
Yes of course. Autopano can not show what has not been photographed. So removing tripod with masking can only be done if other photos show what is underneath there.
#9 2013-02-21 13:38:37
acf-fotografia
Website
I'm working with a Intel Core i7 CPU 860 up to 2'80 GB, 8 GB RAM and 64 bits operative system.
Shoting in bracketing (3 exposures) with a Nodal Ninja 4 up to 130 images, including cenit and nadir images (with and without tripod).
After panorama stiching (with licensed 64 bits Autopano Giga 3.0.3) and turn it 90 degrees i start to fix green targets to preserve cenit without tripod images and red tagets to tripod erase (both cases tool stack option). After tool aplying, turn back the panorama to its original position and renderize it.
Sometimes i get what i want but not always.
I'm sure that i'm doing something wrong, but i can`t find it.
I have experience with Autopano Giga, but masking tool is driving me crazy.
Is posible to get the Autopano Giga 3.0 PDF user manual? or at less information about how to use masking tool.
Thank's
#10 2013-02-22 17:25:42
Website
Did you read this one? http://www.autopano.net/wiki-en/action/ … sking_tool
#11 2013-02-23 10:14:36
HansKeesom
Website
Thank's
Do you use the preview mode to see in between what the result is likely to be?
If you want I can have a look at your photos and see if things can be solved.
