#1 2013-01-25 15:56:40
IgorT
Need help with coding for mobile version
Good day!
Help me please if you can..
I use the PT1.8. Tours from it I modify by the own pattern  (interface of pano).
My problem is with the map which connects to the tour as:
Code:
<include url="%BASEDIR%/../../../plugines/Maps/map/ru-ru/map.xml"/>
If to run the panos from PC - all is fine, but when run from Ipad/Iphone, shows an error "--many symbols--/plugines/Maps/map/ru-ru/map.xml - loading error (IO Error)".
So, how to fix it or how I can to include the map only in PC-version.
P.S
Sorry for bad english
#2 2013-01-25 17:47:49
Website
Re: Need help with coding for mobile version
Welcome to the forum...
I may be mistaken but I believe the Panotour maps feature is not (yet) supported in the iDevice compatible version of tours; currently it uses a Flash based plugin.
However you should not get an error message if using standard output from PTP with mobile compatible output selected, you should merely not see the map when viewing the tour.
#3 2013-01-25 22:26:41
IgorT
I found the cause of error.The code "%BASEDIR%/../../../plugines/Maps/map/ru-ru/map.xml" flash reads as "climb up on 2 levels" and java-script - "...on 3-level" and therefore displays an error that is not on this address. the .xml-file.
