#1 2013-01-21 20:21:54
claudevh
Website
Sky-Watcher Virtuoso Versatile Mount
Hello all,
Have a look hereafter;
http://www.celestron.com/astronomy/cele … unt-1.html
http://www.celestron.com/ajax/ajax_acti … ct%20Tours
Allready sold in North America and in Europe ...
This seems like a "small Allview"
If you have more informations, please share ...
cool Claude cool
#2 2013-01-21 20:48:06
Website
Re: Sky-Watcher Virtuoso Versatile Mount
Mmm, but it will be nearly impossible to rotate yaw axis arround the NPP... And the footprint is very large.
Too bad, as it looks great!
#3 2013-01-22 05:54:48
vincen
Website
it's also very heavy (5kg) and I don't see a way to screw it on a regular tripod, I can only see it on table mount....
Blog: http://www.skivr.com
My shop for panoramic photographs: http://magasin.skivr.com
Nodal Ninja 5 R-D16 on Benro Tripod + Ultimate R1 on Nodal Ninja P2 + Nikon D3X/D3/D90/D800 + Nikkor 10.5 + Nikkor 14/24 f/2.8 + Nikkor 70/200 f/2.8 + Sigma 150-500
Panogear + Papywizard sur Neo
#4 2013-04-16 10:34:23
hyeena
Can you use this head with Papywizard? And/Or Chronomotion? I mean how much does this differ from Acuter Merlins interface/protocol?
#5 2013-04-16 17:25:57
claudevh
Website
Welcome on board "hyeena" !
The Virtuoso Versatile mount is using the same "Interface & protocol" as the Skywatcher multifunction and the Skywatcher AllViev mount !
So No problems wit Papywizard, Chronomotion or PanoramaAPP !!!
The only problem could be "potentiel allignment of the camera to the NPP" witch can give problems for spherical panorama's ...
This is due to the Virtuoso construction ...
I have not yet really be able to check this last problem....
cool Claude cool
#6 2013-04-17 00:22:09
Website
looking at the Image showing the Virtuoso from back side with the cam mounted it seems for me nearly inpossible to set any near correct NPP even with an mobile phone using Portrait mode... (I assume the screw on bottom is the Center)
and it seems to be a device for tables etc. I could not verify that you can Mount it on a tripod...
Uploaded Images
#7 2013-04-17 00:47:11
claudevh
Website
Hello Georg,
You can attach the mount to a tripod ...
This is a extract of the manual:
Note: If you wish, you may attach the base of the Virtuoso to a
photographic tripod. Simply use the threaded 3/8” hole in the
center on the underside of the base plate.
Manual in the next link:
http://www.celestron.com/portal/skywatc … mount.html
This is not excluded that it could be possible to dismantle the base from the vertical part to gain the space to align the NPP ...
This is only a supposition ...
Actually, I have never had the Virtuoso mount in my hands ...
cool Claude cool
