#1 2013-01-09 08:12:27
Pheliciano
Displaying a Title and Description for Panos
I have a client who has asked us if we can add a field to our Virtual Tour that displays the name and a short description of each panorama as it is being viewed. They want it to be static on the screen as the panorama is navigated and for the contents to change each time a new pano is loaded. Is this possible to do using Panotour Pro?
Thanks.
#2 2013-01-09 11:28:07
Website
Re: Displaying a Title and Description for Panos
Thanks.
Not directly via the GUI. You will have to edit the XML files.
I suggest you use the code created by the Logo feature as a model.
I seem to recall that something like this is promised for V2.x of PTP.
#3 2013-01-10 06:40:16
Pheliciano
Thanks Andrew. I hope it is included in V2.x as it seems like a very useful and flexible little addition.
