#1 2013-01-05 23:56:43
esotericvision
Panotour Pro, KR Pano, and Android Jelly Bean
I can't get the panos to play on the new Nexus 7 tablet. Apparently flash will not be supported on the Android Jelly Bean platform. Is there a work around for this issue or am I doing something wrong? Shouldn't the panos play using HTML5?
Best Regards,
Ben
#2 2013-01-06 00:23:33
Website
Re: Panotour Pro, KR Pano, and Android Jelly Bean
esotericvision wrote:
Best Regards,
Ben
See: http://krpano.com/docu/html5/
This relates to krpano 1.0.8.15.
Panotour Pro 1.8 currently incorporates krpano 1.0.8.14 and the mobile-compatible tours it creates play correctly on iDevices, within the limitations of the krpano HTML/javascript Panorama Viewer 1.0.8.14.
