#1 2012-12-25 17:32:46
ori0n
Question about "using ipad to sync direction of view" and watermark
Hi
I had tried to do some searching in the forum and had some difficulties. Please kindly help me with the following 2 questions:
1.  How can I make my virtual tour on my ipad "follow" the way I face my ipad?
2. Can I insert my image in the tour but make it slightly transparent? Its like having a watermark on my tour.
Please do kindly advise.
Justin
My Equipment:
Nikon D5000, Samyung 8mm fisheye lens, Giottos tripod, Nodal Ninja 3 with EZ-Leveller II, Trigmaster
Always trying to learn new things.
#2 2012-12-25 17:44:33
Website
Re: Question about "using ipad to sync direction of view" and watermark
ori0n wrote:
Hi
Like this:
Uploaded Images
#3 2012-12-25 17:45:46
Website
Justin
Do you want the semi-transparent image to rotate with the pano or not?
#4 2012-12-26 05:07:43
ori0n
Justin
Yes, I am looking at those "watermark" that stays with the window even when the tour is moving around.
My Equipment:
#5 2012-12-26 05:09:09
ori0n
mediavets wrote:
ori0n wrote:
Hi
Like this:
Let me test out on my pc later to see it is the function I am talking about.
My Equipment:
#6 2012-12-26 11:29:24
Website
Create  your watermark image using a graphics editor that supports creation of formats with transparency  -  the PNG format works well in PTP.
Use the Extras/Logo feature to add your watermark image to the tour - see first screenshot.  Note if you set one dimension as zero the image will retain its aspect ratio.
As you can see in second screenshot the semi-transparent watermark image overlays the pano image and does not move with the pano when it is panned or zoomed.
Uploaded Images
#7 2012-12-26 13:56:59
ori0n
Hi, thanks for your advise. It is very useful and I realised how useful this software is! Thumbs up!!
My Equipment:
#8 2012-12-26 14:19:41
ori0n
Just to update, I have successfully incorporated a floorplan and also the watermark. Thank you mediavets!
My Equipment:
