#1 2012-12-23 08:46:26
Website
HDR using apg 3.1
I first tried using the new apg V3.1 trail with my new testing.. but... roll
I know I had my rails all set right so I just used my pre-programmed settings in my VR Drive.. I set my rails up and captured a pano with 8-bracketed shots. After my issues with apg I then processed the images through Photomatix Pro.. The images lined up and looked fine.. I then imported my images into PTGui Pro – The results are perfect… !! No stitching errors at all..
Now its ok suggesting that I have not set my NNP correctly but I think it is.. I also realise via testing that the NNP setting using my NN4 produced different results depending on the software I used apg or PTGui Pro.. It took me a while to realise this. My feelings are, this should not be happening… The NNP is the NNP and therefore it should just work no matter which software is use..
Ok, perhaps my NNP is out, but since I am certain its not, I have no idea which way to move it since its now a guessing game.. So, does anyone else have my setup, using a D800 with a VR Drive II and a 10.5 Nikon Fisheye lens? If so, what are your A and B rail settings.
I processed the images through 2.6 and 3.1 trail version. They produced different results as you can see below.. There is no point in posting the PTGui image up since it’s perfect..
What I intend to do now I move the rails to get the best results out of apg, and then I will see how PTGui coups with the same setting...
I have tried using the HDR option in apg V3.1.. AGAIN!.. I really do not get how the video of apg working seems to suggest its so responsive.. My Mac is not a crappie machine yet it locks up when trying to use the HDR. It becomes unresponsive. The HDR option has, for me, never come up to expectations, however I am more than willing to attempt give it a try.. I have now tried a few times with the new V3.1 but I have had to force quite since it became unresponsive.. I am not going to buy a new more powerful Mac just to use V3.1…
One thing I did like about apg 3.1, it automatically detects your bracketed shots.. its stitched fairly quickly and I set it to HDR to detect all pixels. That is really as far as I got.. It then began to lock up.. You can see that in this image below.. I have no answers for these issues.. One thing I am convinced of is apg does not like images processed using Photomatix. But what else do I do if apg will not process the bracketed shots..  I will try again but reduce the image since the D800 captures huge images @ 36.3 mp..
Uploaded Images
#2 2012-12-23 10:25:46
Website
Re: HDR using apg 3.1
There is a fundamental issue with apg HDR.. WIth Photomatix, you simple process ONE set of bracketed images to achieve the desired effect.. Then you can batch process the rest of the images prior to stitching... WIth apg however, you actually stitch the entire bracketed pano sets, resulting in a huge file to play with so as a consequence it takes for ever to see any of the changes, only to find they are not as desired so I keep on going and going.. But even if after a lot of time getting it right.. What do you do with the other +++ panos in the same set..???
I have truly persevered with apg for two years or more.. Each and every time I attempt to go about it with a fresh attitude and new versions of software, I really have to come up with the same conclusion with apg.. Its is not great for bracketed images, HDR or LDR...
I have resized my images by a 1/3 of the size so file size is not an issue.. Or at least it shouldn't be an issue.. However, by the very nature of how apg processes a HDR pano, by using the entire set of bracketed images, it still takes very long time.. I just closed it since its just so irritating watching a loader take forever to make changes.. I will try again later with 3 bracketed images...
#3 2012-12-23 12:23:15
lumelix
Hi
Nikon D800 has a FX sensor. And the Fisheye Nikkor 10.5mm is for DX cameras.
Are your settings correct for this unusual combination ?
To set the nodal point correctly, see :
http://www.autopano.net/wiki-en/action/ … a_panohead
http://www.johnhpanos.com/epcalib.htm
http://wiki.panotools.org/Entrance_Pupil_Database
Regards
Martin
#4 2012-12-23 12:41:31
HansKeesom
Website
What a the group settings you use, especially the block called 'links'?
Regards,  Hans Keesom
I stitch and render for other photographers see http://tinyurl.com/brxvlhg for details
#5 2012-12-23 12:49:19
Website
Hi.. Yes.. When I put my 10.5 on my D800 is automatically sets it to DX mode output... You can override this but no point.. As soon as I put an fx lens on it recognistes this and goes back to fx mode..
lumelix wrote:
Hi
#6 2012-12-23 14:44:53
Website
Could you precisely describe what your processing is like? Does the camera tell APG it didn´t use the sensor full-scale?
What about the head´s xml? Dose it know you used a FX camera in DX-mode? Does it tell the import-module?
I tried stacking in APG sometimes. It works - but i realized stitch-errors because of (i guess) issues setting CPs when optimizing on very bright and on very dark images precisely to the same pixels.
A workaround might be: taking ONE layer for seeking CPs, saving the "construction" and using the cp-placement for the other layers too.
But to be honest: using Photomatix first to make HDR-images and tonemap them before stitching i definitely like better for "usual" equi outputs.
On the other hand: if you NEED HDR-spheres for IBL you need to stitch bracketed sets for outputting the stitch as "true" .hdr/.exr equis.
#7 2012-12-23 14:51:30
HansKeesom
Website
The workaround you describe, you can have using group settings -> links-> detecs links in : The reference level....right?
#8 2012-12-23 15:45:13
Website
I guess so. wink
best to you, Klaus
#9 2012-12-23 16:54:47
HansKeesom
Website
destiny can you try again using the groupsetting mentioned above?
#10 2012-12-23 17:25:46
marco.lanciani
Website
Stitching errors in APG are mainly due to, at least, two issues:
1. CPs, using fisheye lenses, are still not enough spread, both ways, (a) eachother and (b) along the full length of the overlapping areas of adjacent images!
(or put it another way: CPs are way too much clustered and center-positioned on the overlapping areas of adjacent images!)
They say APG has a fantastic algorithms that find CPs where none App is able... but do I need 50 or 200 CPs, all of them close eachother, where none App is able to find them and ZERO CPs where any other App CAN find them, just because there is enough detail, while APG CAN'T?
2. It's still not possible to have at the same time, "find CPs on all stack levels" and "use hard links"!
The idea on this is very easy: to use the stack as a single image but, at the same time, take advantage of the multiple exposures to find CPs, for example, on the highlights of underexposed images and in the shadows of overexposed images... just to have better spread CPs that cover the full length of the overlapping areas between adjacent images, with each image being actually a stack, just taken as a single image by APG during optimization!
It is just not possible to find CPs, equally spread, using only one exposure of the stack, like midexposures, because any detail in the highlights and in the shadows would be clipped (that is too white or too black) and so useless to find CPs between overlapping areas of adjacent images!
But APG Team insist on saying this is not possible because there would be a conflict... I still don't think so, because of the above explanation!
(just to be clear: I'm not saying to find CPs between images of the same stack!)
3. APG is not able to detect an HDR sequence and show it as a stack after importing: I use both In-Camera HDR and the Promote Control.
I have to do it manually every time.
My opinion: Kolor Team should invest more time on CP generation and optimization on the next 3.1 version rather than color issues, as they anticipated.
It's still possible and easy to color correct in Post Processing a perfectly stitched pano... but who needs a badly stitched pano with perfect colors?
Also, when using XML Templates I'm missing a lot of options in the preferences tabs... then I set the EXIF Info for the lens in preferences tab but I always find the value on the XML info, for the lens, on the pano properties (but maybe this is a bug already solved on the last version, I didn't tried yet)... and how can I be sure APG keep the informations from the XML Template when stopping the detection to set my preferences, like a bracketed sequence, because such preferences are missing at the moment of importing the Template?
Let's hope in an improved APG 3.1 for the next Year!   smile
Regards,
Marco
#11 2012-12-23 18:25:51
Website
Hi Marco!
I definitely agree! Sometimes the strategy of seeking and placing CPs seems somewhat funny (not to speak ridiculously) Clear structures (window-frames, crossing lines and so on): not a single CP: they´re all on some more or less featureless surfaces, in moving clouds and so on.
My head positions very, very precise - the result is a very good pattern of images. Optimizing this already very good pattern sometimes results in hours of manually correcting stitch-errors the optimizer produces . . . that´s not funny at all. I think we need an option to tell the optimizer to look only in a close area around the already well placed images.
Trying to use the settings "low, standard, high" for detection doesn´t help much without knowing what EXACTLY it does using any of these selection.
(i´m NOT speaking of images showing sensor-dust or vgnetting which may puzzle the opitimizer).
I had 4 panos some weeks a go which i didn´t get stitches well after trying TWO WEEKS. In the end i did it by retouching in Photoshop and letting away floor and ceiling.
Yesterday i gave the actual version of PTGui a try - it now also imports PapyWizard xml - and . . . what can i say: nearly perfect stitch needing two minor glitches to be retouched. I had lots of sensor-dust and used f11 - deadly - nevertheless PTGui did extremely well.
I don´t intend to switch to PTGu - i´m used to APG and i love it, usually it works fine! But to be honest: i definitely was impressed what PTGui did and what APG didn´t . . .
#12 2012-12-23 18:27:30
HansKeesom
Website
I will just respond to point 3. This is a setting you can choose. Works great for me.
Just goto edit-settings->images->Stacks. Choose the second or third option. Let us know if that changes things for you
#13 2012-12-23 19:28:52
marco.lanciani
Website
klausesser wrote:
My head positions very, very precise...
Hi Klaus,
I do agree with your findings... my panoheads position themselves very precisely too: images need only minor optimizations and the recent ability of PTGui to import XML Templates improves its results even further.
99% of the time clicking in "create pano" in PTGui gives a completely errorless stitch: no manual intervention needed.
99% of the time clicking in "detect pano" in APG gives only a full of error stitch result, that even countless hours of time of "trials and errors", trying to tweak undocumented features, can't resolve...
I do would like to set my workflow on APG but at this stage I still don't see any advantage on upgrading my license to V3, because there is just ZERO IMPROVEMENTS on CPs Detection and Optimization over V2.
Obviously I'm speaking only about issues related to fisheye lenses!
Regards,
Marco
#14 2012-12-23 19:32:25
marco.lanciani
Website
Hans, I've found and activated the option (it's the second option): next time I'll use APG I'll see... Thanks.
Regards,
Marco
#15 2012-12-24 00:49:02
Website
Hi.. OK.. much better results but oh man.. The bending took forever.. I have learnt in the past that if its not working, to turn off and reboot.. I ran out of time last night but this morning I am much happier with the results from apg.. I have to acknowledge that my NNP must be out a bit.. I am still not happy with the HDR results but I think perhaps I now have a starting point.. I will try to force the images into order by renaming as suggested in the images naming image...
As you can see my stitching is not perfect which I conclude must be my NNP not set correctly.. But this time around the air con' it was perfect.. However, PTGui Pro made a really great job of it and using the Photomatix images.. I am really impressed with PTGui Pro and its very quick..!! The blending process of apg was painfully slow..;(
I would like to ask Kolor to focus on facilitating the use of Photmatix images since not everyone wants to use the fusion/HDR feature in apg..
These images below show my settings. Any suggestion on this would be appreciated. It has to be said that apg is a much more feature rich software app than PTGui, but in my opinion it still fails in HDR. It might well be a lack of understanding on my part but I will remind myself that its is supposed to be automated to a high degree.. Also, it has to be a must for future versions to have an option to save the personal settings for future use..
Uploaded Images
#16 2012-12-24 01:26:02
Website
Hi.. I am now testing out the Fusion option panel.. I moved the Exposure target over to the right just a little and wait.. and wait.. and wait.. and wait.. I guess if I waited long enough it will show the result.. but what if its not as I want and have to move it a bit more.. I think after 30 min its long enough with the waiting.. This is just one pano.. What if I have a set of panos taken at the same time with the same exposure and light etc.. There is no way to save my settings to pass on and batch process so I have to do the wait thing again.. I would have to take a screen shot of the settings and try to copy that to the next pano... This is not a great tool at all..
Well, got fed of of waiting so I closed that window and....it did  not like me doing that.. What do I do now... start all over from the beginning I guess.. Does the apg 3.1 come with with a super computer!!..
Uploaded Images
#17 2012-12-24 08:59:39
HansKeesom
Website
Well, one thing you could do is use wetransfer.com to send me the photos and let me have a go. Who knows my settings/way of doing things helps. Free of charge of course.
send it to hans@alsofjeerbent.nl
#18 2012-12-24 09:11:57
Website
Emm. Thanks for the offer, and I will but with a different set of images.. I don't want to board cast my messy bedroom to the world.. It was the only room I could close the door without a pair or little eyes staring at the VR Drive do its thing..  lol ..
I will try with a new set after Christmas.. Firstly, I need to make sure my NNP is perfect.. I really thought it was but perhaps not.. I would love to be able to use apg without issues. I might well be doing something wrong without realising it..
#19 2012-12-24 14:52:22
Website
A word to V3.0 and masking ghosts:
I like the masking in APG much better than the one in PTGui.
Masking in PTGui is very precise - but creates hard cuts.
Masking ghosts in APG seems not only more comfortable but also the results are smoother because APG blends the removals much finer.
Once getting used to it i like it very much and working with it is very intuitive and fluent.
The only issue - in my eyes - is the settings for optimization-sensitivity.
#20 2012-12-24 19:25:03
HansKeesom
Website
Emmm bummer, was so ready to test my stitching skills...... guess we have to accept we will never know whether APG is really that bad .....
#21 2012-12-24 19:53:07
marco.lanciani
Website
Klaus, thanks for the infos. I still don't use too much masking tools so it's interesting to know... by the way, I tried the masking tool in both Apps and I think using it with bracketed sets of 9 (or more) images per set is really a pain, either ways.
Anyone knows how the mask tool, in case of HDR panos, in APG works?
I mean, PTGui apply the same mask to linked images: is it the same in APG or is there some sort of more freedom in this regard? Think about moving objects, not only between sets of images but also within bracketed sets...
And, what about ghosting removal in APG? Where does it work, actually? Between sets of images, within bracketed images or either ways at the same time?
Regards,
Marco
#22 2012-12-24 22:41:59
HansKeesom
Website
Masking with brackets can be speed up by using the fat red and green targets. Works great although I would also like option to scroll a bracket at a time when not having moving objects inside bracket.
Marco, let me try to say this carefully, reading your last post I feel like you are less motivated then me to accept the solutions APG is offering and are more motivated then me to get the people of Kolor to make APG work the way you want.
It reminds me of a saying in my native language that says "if things don't go the way they should go, make them go the way they can go" ( sometimes we add "said the farmer and he placed himself in front of the plough"  )
#23 2012-12-25 00:23:36
marco.lanciani
Website
Hans, I was asking, actually, just how the mask tool in APG works... and how the ghosting removal works... in case of HDR panos with large sets of bracketed images.
I wasn't asking features for APG, was I? smile
Regards,
Marco
#24 2012-12-25 00:39:31
HansKeesom
Website
In my workflow, I never wait for the detection or the rendering. Before detection phase I check all groups and then send them off like one big batch. If it takes 24 hours to get all groups done it is fine with me.
While editing I first edit all groups and check them with preview up to 25%. Only when all groups are ready I fire off all groups for rendering. Sometimes it will take all night to get them done, I just leave the workstation alone.Yes I have some issues with APG (and people from KOLOR) being stubborn and forcing their defaults for fisheye on my projects. It does forces me to either change these settings before detection or in the editor which forces me to run an extra optimalization, waisting my time (http://www.kolor.com/forum/t15931-app-3 … -and-group), but I get where I want in the end while spending an extra two-five minutes on each panorama, so the costs of their stubborness is limited.
All this is done on a i7 920 so not that much of a supercomputer. I think you don't need that, you might just need a change in workflow ;-)
#25 2012-12-25 00:49:25
HansKeesom
Website
Regards,
Marco
Sorry that was not clear.
At http://www.kolor.com/image-stitching-so … ature.html look for "Simple and efficient Mask tool: just place green targets on what to keep or red targets on what to discard"
Also read http://www.autopano.net/wiki-en/action/ … sking_tool
There should be some videos No link at the moment.
Once you get the basic idea of red and green markers you can do so much with them....
