#1 2012-12-17 18:55:33
PaoloRossi
strange alignment problem with GigaPan plugin in Autopano Giga 3.0
I've a strange issue with GigaPan Plugin in Autopano Giga 3.0:
While in Autopano 2.6.4 the stitch was correct, after the upgrade, the panorama results confused and wrong aligned (every time at same bad positions)
I'm missing something?
(see the images)
1) results in  autopano 2.6.4 (correct)
2) results in  autopano 3.0
3-4-5-6-7) settings for GigaPan Plugin in Autopano 3.0
Uploaded Images
#2 2012-12-17 19:35:55
Website
Re: strange alignment problem with GigaPan plugin in Autopano Giga 3.0
I encountered in one (non gigapan) case following: if you change detection quality from normal to strong than you get result like with 2.6 with normal detection.
#3 2012-12-17 20:09:58
Website
oops - that´s funny cool
#4 2012-12-17 20:46:39
PaoloRossi
Tried right now, but the only difference was in the time needed to complete the task (more and more longer): the result panorama was disorder like before. hmm
Maybe a bug in then new GigaPan plugin?
Paolo
#5 2012-12-18 09:20:44
ThomasV
Did you try to use hard links ("Blocco : Utilizza i colegamenti rigidi") ? Maybe the algorithm fails at finding control points between several images.
Regards,
Thomas
#6 2012-12-19 08:31:58
PaoloRossi
Nope Thomas,
Same weird result hmm
Seems the new plugin won't work in any way for this sequence, very strange ...
#7 2012-12-19 08:53:58
ThomasV
Hi Paolo,
It would be nice if you could share your pictures with us, so that we can have a look at it and fix the Gigapan plugin. You can upload an archive on our ftp server (http://www.kolor.com/forum/t766-ftp-server).
Thanks a lot,
Thomas
#8 2012-12-19 10:05:33
PaoloRossi
ThomasV wrote:
Hi Paolo,
Thanks a lot,
Thomas
Thomas I've found the issue!!!
After I have captured the whole scene I've retaken some bad shots, then I've renamed the new file with the same name of the bads to replace:
In 2.6.4 this works like a charm, but in the new version, the engine sorts the files by the Exif time of shots so this confuses the assembling phase.
I've modified the Exif date of the replaced shots and the panorama now is correct smile
Maybe could be useful an options to force the sort by file name? (in some cases could be practical)
Paolo
