#1 2012-12-13 19:26:07
kosmomedia2004
android & Object Movies / Multi-Frame Panos
I have two questions:
How can I play my panotours on android?
And is it possible to make 360°-produkt views with pano pro? (Object Movies / Multi-Frame Panos) http://krpano.com/examples/objects/#top
#2 2012-12-14 11:02:30
Website
Re: android & Object Movies / Multi-Frame Panos
kosmomedia2004 wrote:
See: http://krpano.com/docu/html5/
As I understand it Android doesn't yet offer the technologies required to display panos in a consistent, stable and reliable form. This is not a problem with Panotour Pro nor with krano but a problem with Android.
Not from within the Panotour Pro program; but if you have Panotour pro you can export the embedded krpano/krpanotols license and then use krpanotools as decsrived in the link.
