#1 2012-12-06 21:10:00
marek.garamszegi
HELP ! What I am doing wrong ?
I shoot indoor spherical panorama with Gigapan and floor shot by hand. (picture with my legs big_smile)
Puctures are shooted with 3 steps of bracketing and after bracketing is "Enfused" with EnfuseGUI.
Enfused pictures and settings of Autopano Giga are here:
http://www.fokr.cz/enfused.zip
After a lot days of work, I am not able to make spherical panorama without errors. Specially I have big trouble with ceiling. Autopano is not able to make controlpoints on celing using Similarity or Homohraphy...
Can anybody told me, where i am making mistake ?
Thak very much for any help !
Marek
#2 2012-12-06 23:25:31
Website
Re: HELP ! What I am doing wrong ?
first - it can be done - thats the good answer.
but ... smile
if I take all 25 images of your zip file - it fails.
+ some reasons maybe: mix of focals - the nadir handheld shot does have 18mm the others 15. - i did not use the handheld nadir image with your feet (handheld + non 90" to bottom angle will in most cases not work).
+ the 15mm images are recognized as non fisheye. this maybe correct or may not. one rule: if having troubles with 15mm or smaller that are nonfisheye recognized than try it with changing in image properties to fisheye. -  I did change it to fisheye.
+ you shot with a regular image matrix - this leads to an rather big overlap in zenith row - I finally did use 5 images less... so in sum I used only 21 image to still cover the sphere.
+ you shot in landscape mode. - this may work or may not - but general practice is using portrait mode images. Advantage on indoor panos is you need less rows... and you've less ghosts from moving people (if there are ones...)
+ in screenshot you can see that autopano detected CPs between some images and between some no CPs could be detected. so I did delete all links between images not directly being neighbor images. and I manually added links between images to link the images. this dramatically reduced the detected RMS and the ceiling errors could be corrected as shown in preview mode...
+ you've dust on your lens or on your sensor. if dust is on the images (always on same x,y position) than make sure not CP's are detected by accident (didnt care about it and it worked...)
I did use apg 3.0 final. I used
Detection Quality Standard
CPs: 50 with Ransac model: Similarity
Blending settings: Multiband Level 0 with Fusion and Cutting enabled Priority to Ghost.
the screenshots:
3. mage: using nonfisheye properties and with default recognized CP connections
4. image: using with fisheye properties and after adding CPs to connect images
2. image: is the preview (preview feature with apg 3.0)
1. image: finally the resulting pano using 30% original size and 75%jpg quality compression to fit in the forum
and what with the nadir: I would use krpano tools to create cube files and postprocess the regular pattern. the corrected cube files can than remerged to a rectangular image with the kroanotools...
Liebe Gruesse,
Uploaded Images
#3 2012-12-07 00:17:08
Website
That's because he used a Gigapan robotic head - Gigapan robotic heads can only shoot a regular matrix of images, and can only mount the camera in landscape orientation. Just two of the reasons why they are not really suited to shooting sperhical panos.
#4 2012-12-07 00:26:50
HansKeesom
Website
Using a gigapan for indoorshots.....is a bit like using a pickuptruck to serve tea....if possible go manual indoor. It si then also easier to skip a few shots in the zenith.
Regards,  Hans Keesom
I stitch and render for other photographers see http://tinyurl.com/brxvlhg for details
#5 2012-12-07 00:27:17
Website
@andrew... uups and aah! wink
lg
