#1 2012-11-28 07:46:35
SimDC
APG 3.0.0 RC1 W7 64 doesn't flush memory after each pano is done
APG 3.0.0 RC1 W7 64
If APG remains open to render successive panos of the same images,
RAM builds up.
#2 2012-12-03 11:16:47
renan
Re: APG 3.0.0 RC1 W7 64 doesn't flush memory after each pano is done
Actually, rendering memory is reserved at start up but appears used on real rendering only.
If you are making successive renderings without use all allocated memory, system (task manager) shows increasing memory use. But when all allocated memory is used, it will be recycled between successive renderings.
