#1 2012-11-26 04:28:39
sisikira
Website
about screen edge distortion !!??!!
I think all of you see the distortion at the edge of the screen.....UM...like this image.
but on IPAD or IPHONE, this problem wont happen. I use the REDUCE DISTORTION function, but doesnt help much.
I have seen other software can make perfect panorama tour without any distortion.
any suggestion ?
http://dreamhometour.ca/test.html    such as this one. no distortion at all.
Uploaded Images
http://www.flickr.com/photos/sisikira/     Flickr album show   add me up big_smile
#2 2012-11-26 05:52:24
aromer
Re: about screen edge distortion !!??!!
I've always found that using a FOV around 75degrees minimizes edge distortion.  You will find that in the examples you posted if you zoom out (to around 90degrees) you begin to see distortion much like what you have in your example image.
#3 2012-11-26 07:16:50
Gund
Limiting the FOV or setting fisheye view on 0.35 at default may help to reduct it.
I always set the default view too fisheye 0.35 - panoramas look much less skewed.
#4 2012-11-26 17:31:16
HansKeesom
Website
ipad and iphone are not as wide as your computer screen. Therefor they show the middle parts of pano and not the left and right parts.
Regards,  Hans Keesom
I stitch and render for other photographers see http://tinyurl.com/brxvlhg for details
