#1 2012-11-18 19:03:50
juanelodi
I have problems with my license
I have problems with my license...
I just bought the license of PTP, I can see the project in my coputadora, but when I upload to ftp says license error.
:Here is the link:
http://bluewired.info/360/13/13.html
http://bluewired.info/360/economica.html
#2 2012-11-18 23:29:15
Website
Re: I have problems with my license
if you open in ptp menu help->about:
what is displayed in first two lines? (licensed to xyz or demo mode or...)
while tour creation: did you use the embedd all option? if no, did you export your tour to an empty directory and did upload this directory including all files/directories/subdirs to your webspace?
#3 2012-11-19 08:08:47
Administrator
Website
It seems that you used the "Restricted domains" field in the build properties tab.
You can get this "License error" message, if the domain from which you play the tour is not in this "Restricted domain" field.
So verify that you entered correctly your domain name, that there is no type in the field, or that you used ";" between the different domains, etc...
http://www.autopano.net/wiki-en/action/ … Tour_Build
#4 2012-11-20 22:45:17
juanelodi
If I'm trying to use "Restricted domains", put different forms of domain, example:
http://www.bluewired.info
www.bluewired.info
bluewired.info
If I do not put any domain works,
http://bluewired.info/x2/ptp.html
but I want to restrict and not working
http://bluewired.info/x1/build.html
#5 2012-11-22 10:28:41
Administrator
Website
how did you separate your different domains in Panotour Pro field ?
Did you use a semi column, or a comma ?
