| User list | Rules | You are not logged in.
Pages: 1
My workflow shooting spheres with 50mm eq includes fixing the nadir using krpano Convert SPHERE to CUBE droplet to get a down-image. Then I repair the nadir and convert it back to sphere using krpano Convert CUBE to SPHERE droplet.
Technically this works well. Now, by accident I noticed that this back and forth changes the colors, the result is a less vivid pano.
The pano is rendered in APG 3.0 B3 to PSB (from TIFF sources) and krpano convert it to TIFF.
Is there anybody who has ideas about what to do ?
Leif
i like the bottom one more.....
The top one is the PSB from APG. (from TIFF's generated by DXO)
The bottom one is after back/forth to krpano.
Leif
Hi
Do you use different color spaces or different bit-depth ?
Color shift is normally when change the color space.
Leif
lumelix wrote:
Hi
A vital point! In the prefs for the KRPano droplets you can set "fast" as false or true. Use "false".
You also can set it - preferable - to the same format as the input. In this case: .psb.
I never had the colors changed this way.
In the convertdroplets config there is nothing about colorspace.
I have used the default setting:
[Convert SPHERE to CUBE]
cubeformat=CUBE
cubesize=auto
outputformat=tif
tiffcompress=lzw
jpegquality=85
jpegsubsamp=422
jpegoptimize=true
fast=false
I will change the output format to PSB and have look.
Leif
I have changed the output format in the convertdroplets.config:
cubeformat=CUBE
cubesize=auto
outputformat=PSB
[Convert CUBE to SPHERE]
spheresize=auto
outputformat=PSB
Then I ran a roundtrip sphere->cubeface->sphere and voila !
There is no colorshift
Solved. Thanks to Klaus for the tip :)
Leif
No, it was the difference between TIFF and PSB.
There probably were several colorspaces defined.
Color shift -> different colorspace and/or bit-depth.
Compression or chroma subsampling should not affect the colors
in a visible range.
@lumelix
okay, so couple of nerdy questions for you then so I can try and get a better handle on things...
"Color shift -> different colorspace and/or bit-depth."
If both the tiff (uncompressed) and the psb are 8-bit, and are both defined with same colourspace - then they should have no colour difference. Is that right?
would the tiffcompress=lzw not have any effect on the colour then?
Hi con
Yes, it should
LZW means lossless compression and with the same color space and bit-depth
the two images should look the same (overall).
But if you handle with 8bit TIFs, you will lose some fine informations from your camera:
Actual DSLRs works with 12bit, so with 8bit, you loose a lot of color fine toning, 4096 times less (2^12).
Most of time, this is visible in blue sky areas. You will see some banding there, not a fine color gradient.
For best results, work with RAW files and convert them with suitable software to 16bit TIF LZW.
For normal use, 24bit JPGs with slight compression are fine too.
Hi everyone
Haw or where Can I adjust convertdroplets.config
Best regards
M.Estevez wrote:
Hi everyone
Best regards
Folder: KRPanoTools, here "convertdroplets.config"
Hi Klausesser
But I don´t find one for convert EQ to CUBE
My folders order is this
https://picasaweb.google.com/1123179703 … rtEQToCUBE
Best regards
M.Estevez wrote:
Hi Klausesser
Best regards
"Convert sphere to cube" ![]()
Hi
I go to Sphere tu cube and SHOW CONTENT OF THE PACKAGE
In this I find -info.plist -
I open it and change for PSD
but it continues making tiff cube images
I will look for other way
M.Estevez wrote:
Hi
according to krpano documentation the cube to sphere and sphere to cube droplets are based on the tool ktransform and on its docu page psd/psb are also listed as in/output format...
http://www.krpano.com/tools/ktransform/#top
so why not using the ktransform tool directly on command line:
ktransform cube mysourcepanoimage.psd cubesoutputfilename
Online
M.Estevez wrote:
Hi
Wrong place - go to KRPanotools folder and open "convertdroplets.config"!
I have updated Krtools
and now I have "convert droplets.config"
Before I have not it
Best regards
Pages: 1
COMMUNITY Forums YouTube channel Google+ |
COMPANY Blog About Kolor Resellers Contact Visit us |
