#1 2012-11-12 11:05:09
joeborg
Website
Stitch different exposures using the same settings (HDR)?
I typically shoot for HDR images using exposure bracketing and setting the aperture and ISO (i.e. allowing shutter speed to vary). For panoramas, I typically HDR the images beforehand and then stitch the tonemapped images using autopano. That said, I was wondering if there was any way in which to do this by stitching first and then generating the HDR?
What I'd like to do is essentially stitch the three different exposures in the same exact manner. In other words, I'd end up with three tiff files: 1 containing the -2EV photostitch, one the 0EV and one the +2EV. I'd then be able to combine these three tiff files into an HDR image using my HDR software. As I see it, the trick to all this would be to somehow save all the settings for a photostitch and then force autopano to use the same exact settings for a different set of exposures. For example, I'd generate the photostich for 0EV, save all settings and then run those settings for the photostitches of -2EV and +2EV.
Is something like this possible?
Thanks,
Joe
#2 2012-11-12 11:10:33
Website
Re: Stitch different exposures using the same settings (HDR)?
Hi Joe..
In my opinion this is not the best way of creating HDR images... You are better off fusing the exposures using Photomatic or EnfuseGUI and then stitching the fused images using apg.. This is how I do it with LDR and HDR.. The results are far superior... If you do it your suggested way, you will probably get misalignment with the images.. Not a nice look...
#3 2012-11-12 11:16:26
joeborg
Website
Hi Destiny,
That for that. That's in fact what I currently do too. The problem I find with it is that when you tonemap the images, you have to check each fused one first before feeding them to apg. I obviously save tonemap settings in Photomatix and then run the same settings for all images so that I end up with a set of fused images that have the same tonemap settings applied. That said, even this at times produces undesired results (since a panorama spans a large angle, the exposures can vary drastically). Tonemapping the entire panorama from three source panoramas (e.g. -2EV, 0EV, 2EV) might allow me to better judge the tonemapping settings I should apply or, in some cases, allow me to manually layer in photoshop instead (if I see that I done't like the hdr results)...
Thanks,
Joe
#4 2012-11-12 11:26:47
Website
emm... The good thing about Photomatic is the batch processing feature, but Photoshop does a nice job too but unfortunately it does not batch process..  I can almost guarantee that stitching panos at different EV's will not provide for a great output after they are fused together, even doing it manually.... Each pano will stitch according to the best pixels so there will most likely be a mismatch in many areas creating a blur effect.
Normally if I batch process I do not get any issues..
#5 2012-11-12 11:31:00
joeborg
Website
Thanks Destiny,
Yes what you do is exactly what I do. I use the batch process in photomatix. I just thought I'd ask if it's possible to do it the other way round. As you said, if you stitch three panoramas (i.e. different exposures) independantly, then there will likely be a mismatch. I guess I was asking if there's a way to over come that...e.g. by forcing autopano to stitch images x,y,z in the same exact manner as a,b,c so you end up with two panos that align perfectly...
I'm guessing it's not possible. Maybe it would be a nice feature to have...
Joe
#6 2012-11-12 11:32:27
Website
BTW Joe.. How many fused images can your camera capture..?.. I am going to try 7 as soon as I can.. Never any time... 3 is pushing it to get HDR.. You are really in the area of LDR.. You need at least 5 EVs to achieve effective HDR results..
#7 2012-11-12 11:37:17
joeborg
Website
Mine is a D90 so only 3 I'm afraid. I'm jealous of your D800 :-).
The whole reason for this question really is that I use some of the techniques described here: http://www.stuckincustoms.com/hdr-tutorial-part-3/ for normal (non panorama) hdr. In other words, after I process a file with photomatix, I then layer it on top of the original in photoshop and carry out some adjustments using layers/masking etc. Of course, this is not possible for me to do with a panorama since I have no 'original' panorama to layer the tonemapped panorama with...
Joe
#8 2012-11-12 11:38:37
Website
To be honest Joe, I feel that apg is an amazing software app, world class in many of its features, however, in my opinion it lets itself down with the LDR and HDR feature..  What is needed is apg with the ability to not only manage the LDR and HDR better, but stitch the images all in the same process.. In many ways apg already does this; but the final output is not in my opinion the best LDR or HDR image quality....
#9 2012-11-12 11:46:15
Website
Hey, the D90 is a great camera, I love my D90, and you can cheat on the EVs.. When in RAW out put your 3 images at the EV you have set but then change it in RAW 2 EVs up or down depending on what you are wanting.. Now you will have 5 to 6 images... You can do it again stepping it the other way.. I have done this an it works.. Not the very best option but since you only have 3 bracketed image option with the D90 its an option but you can also use software too. You can get up to about 15 bracketed shots I think with software.. You just need a laptop with the software hooked up...
PS.. Your are right to be jealous of my D800, its AMAZING.. Love it love it love. love it!!!. coolcoolcool
#10 2012-11-12 12:20:46
joeborg
Website
Thanks Destiny,
Yes, I'm with you on Autopano's HDR features - it's its achilles heal IMHO. I've never even figured out how to get it to processes bracketed photos (which it should be able to do)...otherwise, it's an amazing bit of software.
Thanks also for the tip about the bracketing. To be honest, I thought that since I output my raw files as 16-bit tiff files into photomatix, then I wouldn't need to manually also export stepped raw files since all the information of my (12 bit) raw files should anyway be in the 16-bit tiff files for photomatix to handle. Still, I'll try your suggestion to see if the results are better.
Glad you love your D800. I'm trying to save up for one and the 14-24 you're also using. I think that's a brilliant combination :-)
joe
#11 2012-11-12 16:36:20
Website
Hey Joe! cool
I definitely see your problem - facing it myself each time i do it cool (which means almost every day). I tried to handle it the way you named - other issues can rise then: as example slightly differenceys in the layers which make it hard afterwards to get a clean mapping.
The ways to go in my opinion are:
1) each time to test more than one  set of images to find the best common settings - which usually works very well with me, or
2) to find out how to achive 3 or more optimal matching layers for mapping afterwards. That´s what i´m evaluating actually - because you have indeed better control for the result of the mapping.
Another reason is: i sometimes need "native" .HDR resp .EXR files for the use as ImageBasedLighting in Maya and Maxwell.
I didn´t care much about stitching bracketed layers - but i´m digging into it actually. It must work - no question.
#12 2012-11-12 16:40:11
Website
Yes - definitely. APG doesn´t do (!)HDR(!) at all. It does fusion.
But that´s not a real problem i mean as long as you get precisely matching layers for mapping afterwards or using the .hdr resp. .exr data otherwise.
#13 2012-11-12 17:06:06
joeborg
Website
Thanks Klaus,
It seems you do have my same exact problem. As you said, wanting a .hdr file for the entire pano is yet another good reason. Do let me know if you come up with a solution...
The closest I've come is through reading this: http://www.autopano.net/wiki-en/action/ … ng_Stacks. That said, I never got it to work as it seems it needs brackets based on shutter priority which doesn't seem to make much sense to me. I shoot my brackets in aperture priority so as to keep DoF consistent amongst the exposures...
Joe
#14 2012-11-12 17:07:33
Website
8bit/TIFF definitely is enough for merging them to HDR anyway. Depending on you motif even JPG does very well -
to be honest: sometimes it´s preferable for making HDR out of a set of 3 using -2/0/+2 (depending on the motif as said).
If you´re able to use MagicLantern or PromoteControl you can expand your bracketing to 12 (ML) resp. 24 (Promote) or more (i tested 12) exposures.
That´s fine for delicate light-situations. I used 7 steps here: http://360impressions.de/ObenAbend/ and http://360impressions.de/Empore/ and http://360impressions.de/ObenNacht/
as well as here (Lots of compression-artefacts in the sky and by reducing to sRGB - original size is about 36000px):
Uploaded Images
#15 2012-11-12 17:15:24
Website
The only priority wich really is essential is: NEVER use ANY kind of automatic on the camera Edit: (when shooting panos)
Manual focus.
Manual aperture.
Manual speed.
Manual WB.
#16 2012-11-12 18:11:22
marzipano
joeborg wrote:
Thanks Klaus,
Joe
That part seems to work OK for me provided you use APG 3.0 not 2.6.4 (where I also couldn't get anything bracketed)
I was using AEB on a Canon S100 where you are limited to 3 exposures and for this to work in APG 3.0, I checked the "Use bracketing to create stacks" box. Taking pano images this way, however, is  partially automatic as the start point for each bracketed set in a multi-image pano is determined individually for each image (either shutter speed or aperture depending on camera setting). As Klaus said, this is not good.
I did the CHDK hack on the Canon and now use 5 exposures with the shutter speed and aperture both set manually and constant throughout the pano (i.e. same start point before bracketing for every image in the pano). This uses the "Continuous Shooting" camera function but the funny thing is when loaded into APG I now have to check the "Always create stacks with N images" (N=5 here) to get the images bracketed in APG in layers.
I am still experimenting as to how to get fused panoramas to render properly in APG 3.0 - at present I am getting much better results by pre-processing in Photomatix and then using APG to stitch the Photomatix output as if they were just single images.
I think the results in APG should be better than I'm currently getting and my belief is that the main problem is the documentation rather than the product itself. It feels rather like the blind leading the partially sighted at present
best
Martin
#17 2012-11-12 18:15:42
Website
Hi Martin!
I definitely agree! cool
#18 2012-11-12 18:44:54
joeborg
Website
Hmm...
I'm a little confused now :S
1. Is APG 3.0 out or is that a beta release? I'm on 2.6.4...
2. I'm not sure I follow what you mean when you say ' the start point for each bracketed set in a multi-image pano is determined individually for each image". To clarify, I usually lock down iso and aperture (i.e. shoot in aperture priority) so that the camera is allowed to vary shutter speed within the bracketed set. I take it there's a better way but shooting in full manual more and setting everything? Why is this better and what does the camera vary if everything is locked down (i.e. so as to obtain the difference in exposure for one given set of brackets)?
Thanks!
Joe
#19 2012-11-12 20:43:53
Website
Joe.. HDR is high dynamic range.. you cannot get true HDR using just 3 brakted shots.. In saying that, you can still put 3 image into software and use the HDR feature, but the output is not true HDR.. You can use 3 images for LDR fusion of images.. Low dynamic range and achieve great results... Even your tutorial uses 5 images for HDR.. From all I have read, 5 EV stops if the minimum for true HDR...
Also, apg 2.6 is fine.. There is more options with fusion of images though in V3... Give it a try out.. You can download the trial.. It has some useful features for viewing.
#20 2012-11-12 21:10:34
Website
Of course you can - but not from AutoPano/Giga. That´s why he wants to stitch each bracketed series first and then merge the three layers
in Photomatix for making HDR and map it or save it as .hdr/.exr.
Output/saving the merged layers as .hdr/.exr (without tonemapping of course cool) is a common process among photographers doing fx .
#21 2012-11-12 21:12:18
marzipano
I tried what you suggest here, it works well as long as nothing moves.. wink and yes, 5 Shots +  per stack does provide the best results.. I have never gotten a great result in HDR using just 3 shots with my D90... Its ok'ish but 5 stack shots make a huge difference when just 3 are used....
joeborg wrote:
Hmm...
Thanks!
Joe
1.Yes Beta 3 but seems pretty stable. I couldn't get 2.6.4 to bracket anything as I mentioned but I believe others had more luck. I'd def. give 3.0 a try though as it also has more specific fusion functions
2. Sorry maybe my explanation was a bit unclear. In a group of (say) 6 pano images bracketed in 3's (i.e. 6x3). Before I applied the CHDK hack I could use Aperture or Shutter priority and specify the +/- EV to apply. So for (say) Aperture set at F4 the 1st bracketed image set might be (for +/- 1EV) 1/150, 1/300, 1/75. However the camera would take a new reading on the 2nd bracketed image set so it might be 1/400, 1/800, 1/200 and so on for the rest of the images . With the CHDK hack I can (and do) specify a fixed aperture AND shutter speed so I would end up with everything at F4 and every set of images at (say) 1/150, 1/300 and 1/75. As I said I use the "Always create stacks with N images" option for this - I use 5 images per set
does this help ?
best
Martin
#22 2012-11-12 21:51:29
Website
Appears so.. http://en.wikipedia.org/wiki/High_dynamic_range_imaging
Which contradicts many other article I have read.. Some of the best HDR I have seen, uses in excess of 15+ shots..
#23 2012-11-12 21:56:27
joeborg
Website
Hi All,
Many thanks Destiny for pointing me to the trial download. I hadn't realised that version 3 was also available. Might try that...
As for HDR, well the reason that tutorial (stuckincustoms) is based on 5 exposures is as per: "Turn on Autobracketing. If you have 3 pics in the autobracket, set it up at -2, 0, +2. On my Nikon D3x, I usually take 5 pics at -2, -1, 0, 1, +2. I’d prefer just to take 3 pics at -2, 0, and +2, but this camera only steps by 1. I think you will find this +2 to -2 range satisfactory for 95% of situations. An exception, for example, would be shooting the interior of a house that is extremely dark and there are windows where the outside is extremely bright."
My understanding is that it's not the amount of pics that makes up the dynamic range but rather, the range of EV you cover with the pics you have. For example, on my D90 I can shoot a bracket of 3 photos at -2EV, 0EV and +2EV. Now, most DSLR cameras would have a dynamic range of around 12EV (Destiny's D800 will be slightly better than that ;-)). That effectively means that the three files combined give me a range of (at least) 16EV. Even if I were able to shoot 5 images with 1EV spacing, I'd still ultimately end up with 16EV so the end result is the same...
The only thing I'm not sure of (but I'll try an experiment some time soon) is whether adjusting the exposure further (e.g. setting my -2EV file a further -2EV in software and my +2EV file a further +2EV in software) of the source images before running photomatix actually increases dynamic range or not. In other words, do I now have a 20EV dynamic range or did the software trick do nothing? My inclination is to think it's the latter. In other words, I think that photomatix is intelligent enough so that if you feed it a source file that's RAW or a 16-bit tiff, it can 'dig out' that extra exposure information contained in such files without you having to adjust the exposure of the source files beforehand. So, I would think that these two would produce the same results:
- 3 source images as 16-bit tiffs from the original raw files at -2EV, 0EV and 2EV.
- 5 source images as 8-bit tiffs. The 1st 8-bit tiff is the -2EV raw file set to a further -2EV in software, the next three are the raw files unmodified and output directly as 8-bit tiffs and the last 8-bit tiff is the 2EV file set to a further +2EV and output as and output as an 8-bit tiff.
Apologies if the above is unclear Destiny. Feel free to question it further. The basic point I'm trying to make is that a raw file (12/14bit) or a 16-bit tiff file has the added exposure information that photomatix can make use of; I don't think you need to manually add output images at different exposure levels set in software.
Martin, understood :-). Essentially it's equivalent to either full manual (I take it your camera doesn't allow this?) or else holding down the exposure lock between different sets of exposures (i.e. so they all have the same shutter speed and aperture). I've never tried this before for bracketing; I've always used aperture priority (read: I've not noticed what the disadvantage may be of having different shutter speeds between sets of exposures?). I'll see what my camera does in full manual mode and AEB set if you say it produces better results.
Thanks all for the very interesting discussion (so far) :-). Might this be something worth submitting as a feature request? In my stupidity, I think it shouldn't be something too difficult to implement. What we're after is a feature that somehow allows you to save all the control points from one run and apply the same exact control points (blindly) to a different run. E.g. Tell the software to treat image 6 like image 1 (in the stitch), image 7 like 2, image 8 like 3 etc without doing any recalulation (simply apply the control points from the previously saved project used to stitch 1 to 5).
Joe
#24 2012-11-12 22:10:01
Website
wink... Just when I thought I understood HDR, i am back on the learning track... wink... I did not know about the 16bit tif... There is so much content about HDR, some of it can lead you into the wrong direction... One of the main reasons why I bought my D800 is to play with the HDR more.. And of course you are right about the interior issues... I saw a great interior HDR image, but it used 12 stacked shots... It was beautiful.. Back to learning HDR ..  lol Thank you for all this info...
The future request you suggest sounds good..wink
#25 2012-11-13 09:17:22
Website
Hi Joe...
My first HDR efforts are at this link below, which I achieved using my D90 at -2, 0, +2 EV.. At the time I thought they were great but now I can be critical of my own work... The effect I do not like about using just 3 shots with HDR is the halo glow effect around the edges and the strange artificialness of the images.. When I used 5 a while back and it began to look much more pleasing.. I need time to play with 7+ with +/- 3/5 EV's...
http://www.destinyvirtualtours.com/DPSn … hy-service
