#1 2012-11-05 10:54:38
rork
Website
FOV - zoom level - distortion in viewer question
Hi all,
With panorama's, I sometimes get the question about the distortion when viewing/rotating the pano.
I always build my pano's to equi 360/180 dgr. versions, so 2:1 ratio.
When building a webpage from PTGUI for instance, I get less distortion when viewing, as when building one from Panotour (v1.5 btw).
The strange thing is that the FOV defaults are the same for both, 90 dgr.
edit: --->
Before I was about to send this, I played some more with a pano from PTGUI and Panotour. It seems the default zoom levels in Panotour are causing most of the distortion.
If I zoom in to appr. the same level as the PTGUI build, I almost get the same view and distortion is 90% gone. Esp. in full window mode the difference is very noticeable.
So I checked panotour, but cannot seem to find a zoom level lock for the pano to start in, it's always a default 'show as much as possible'.
How can I set my default zoom level from within Panotour?
Is this possible? Is this available for Pro? I want to upgrade to Pro soon, as for the extended HTML5 support.
cheers for any answers,
rob
cheers,
rob
#2 2012-11-05 11:43:30
Website
Re: FOV - zoom level - distortion in viewer question
why not using 1.8?
in panotour pro 1.8:
open a tour, klick on one pano, go to Window "3D Editor | Panorama View": on top right position Fov, Vaw and Pitch can be set. These values are used for default opening of this pano.
or in that window: move with mouse to find your preferred position, than right click and use option "set as default view".
#3 2012-11-05 11:48:21
Website
Hey Rob!
Given you did a correct stitching/rendering basically all distortions will be the same no matter which application you use.
By default the maxl FOV is 90° in PanoTour/Pro. Of course you can set it to, let´s say: 70°. This wou´ll have less distortion
while moving around - but that also depends on the kind of location and on your POV.
You can set the FOV in PanoTour/Pro or you can edit it in the XML of your pano.
Afaik PTGui is a stitcher (i have an older version and maybe it changed actually) - but PanoTour/Pro is an application to make the stitched images
interactive.
Basically the stitched image doesn´t determine the FOV when the pano is viewed interactively on screen - it´s the application which makes it interactive
that sets the values.
As i said: setting 70° or even 60° as FOV is more moderate than 90° in terms of distortions while moving - but of course you need to move around much
more to cover a scene. So it´s better to decide individually which FOV suits a scene best.
#4 2012-11-05 11:58:11
rork
Website
@gkaefer:
why not using 1.8?
Because I need a reason (e.g. actual client) to buy into 1.8 Pro.
But I think you mean something else, I have seen those controls. If both the FOV for a PTGUI and Panotour are equal (90 dgr.), the amount of zoomlevel into the pano 'hides' the distortion on the edges.
This is what I tested. The PTGUI version zooms in more into the pano, thus not showing the more noticeable distortion in the Panotour viewed by default zoom. The FOV stays the same.
@ klausesser:
PTGUI gives me perfect stitches, no problem there ;-)
Yes, if I start playing with the FOV (<90 dgr), I get less distortion, but the effect is still more noticeable than playing with zoom.
I found out after posting I can get more or less the same 'look' as in the web export/viewer from PTGUI, when I start playing with the zoom limits in Panotour. Upping to min. zoom to 125% or so.
But I'm not sure if that is the correct way of approaching this.
Hope this makes it more clear.
thanks for the quick replies!!
rob
#5 2012-11-05 12:20:28
Website
rork wrote:
@gkaefer:
why not using 1.8?
@ klausesser:
rob
Rob - sphaerical panos naturally show distortions when you pan around. That´s the nature of wide-angle photography - which shooting a sphere indeed is to the extreme. The only way to avoid it is to limit the FOV - which is comparable as to use a tele lens instead of a wideangle lens. I found 70° is widely accepted by clients and people who view the panos. 70° of course needs more pan and tilt but it´s a good combination of FOV and moving. 60° is even better in terms of the FOV - but you of course need to move around much more and so a natural feeling as an overview is gone.
But - as i said - that depends mainly on the scene/location.
This is absolutely independent from the stitcher-application.
Regarding the zoom-level: NEVER exceed 100%. If you need more zoom-level: use a longer lens for shooting and do more shots.
#6 2012-11-05 12:27:36
Website
Maybe i misunderstand what you´re saying, but: No. Zoom just means limiting the FOV.
At least it does not for me . . visual examples usually make things clearer.
#7 2012-11-05 12:29:07
rork
Website
Hi Klaus,
Thanks for the reply :-)
Yes, going towards 60-70% FOV seems to be the sweet spot. And yes, you need to look around more and so loosing some of that overview.
I never giving it much thought, but I had some comments from people on this lately. So that's why I asked.
I see about the zoom, will not use that in the future for getting rid of that distortion... ;-)
again thanks!
rob
#8 2012-11-05 12:46:26
Website
ROb,
in your first posting you mention you used panotour 1.5... why not 1.8 (free upgrade)?
Im not 100% sure because I ever used the pro version, but I think & expect that the Fov settings are also in the non pro version available...
#9 2012-11-05 12:57:01
rork
Website
Ah... didn't know that <blush>
Will have a look at it.
As far as the question, with both of you replying it is answered for me. I created a version with smaller FOV, and so far the comments are positive.
Thanks!!
rob
