#1 2012-10-23 21:28:37
scrappyRMH
Cutting Size not cutting it
I have a pano image that is 19000x9500. I loaded it in Panotour Pro 1.8 for Mac and hit the "Reduce Distortion" button. It sets the "Cube Face Size" to 6032. I manually set the "Cutting Size" to 512. When I build the tour, I expect the image tiles to be 512 but instead I get image tiles that are 377x377. If I set the "Cutting Size" to 1024 I get image tiles that are 754x754. Is this a bug? I need the image tiles to be a specific size.
#2 2012-10-23 23:21:36
Website
Re: Cutting Size not cutting it
Why?
#3 2012-10-23 23:44:34
scrappyRMH
I'm creating a viewer that uses a different engine. Whenever I load an image that is not a power of two it creates a noticible stutter.
#4 2012-10-25 19:45:10
scrappyRMH
Anyone? Isn't that the point of this option- to cut the images as a specific size? Why is this being ignored? Is there another option that needs to be set? Would it help if I changed the resolution of the pano image? If so, what size would work? What is the formula being used to calculate these slices?
#5 2012-10-25 20:30:02
Website
I suggest to visit the KRPano-site. Panotour/Pro is a GUI for KRPano.
http://krpano.com/ here´s all the information that´s going deeper.
for the use of PTP the cutting-size only matters in terms of loading-speed.
