#1 2012-10-23 16:57:10
tbr
[APG3 B2] W7 64 Bad stitching results using hard links for stacks
Observed on several panos APP 2.6 had no problems with.
5D2+14samyang precorrected images.
With detect control points the resulting stitches were correct though cannot render because of too many CPs for antighost/4 gig system. (?)
#2 2012-10-23 18:24:49
Website
Re: [APG3 B2] W7 64 Bad stitching results using hard links for stacks
Hi!
Could you write what you mean a bit more understandable, please?
#3 2012-10-24 09:08:42
Kolor CEO
Website
I think, he is referring to cache message that says that not enough memory is available for the anti-ghost system.
Try to change the cache size value in generals setting / memory: change from 'auto' value to 1MB value.
#4 2012-10-24 19:53:40
tbr
You're da man Alex!
So i was trying to detect a hdr spherical pano from 54 16-bit tiff images.
This is a forest scene with lots of trees and lots of leaves all over the pano.
Pano setup is nearly perfect, other panos give pretty good results.
I thought i give the beta a shot.
When i choose the detect control points option for stacks, detection was good, but could not render because of not enough memory for anti-ghost.
That is solved with the setting AlexandreJ suggested.
When using hard links for stacks detection gave me bad results.
Guess i have to use detect control points in such cases. Anyway i wanted to give feedback, it may be a bug.
Uploaded Images
