| User list | Rules | You are not logged in.
I need this to be resolved quickly so if anyone has any information on how to solve this it would be much appreciated. Since PanoTour Pro does not allow you to replace a map file in the program without removing all it's hot spots, I opened the kpt file in Taco HTML Edit, and replaced the map file name and hit save. When I reopened in PanoTour Pro it screwed up many, many things. None of the hotspots lead to the correct pano. Some of the hotspots on the map are gone. One of the panos went missing but it looks like that data is no longer in the kpt file.
Here's one clue of something weird I noticed: A long string of text inside the kpt displayed japanese characters.
Please don't tell me to make backups because I usually do. I just didn't think changing one number inside a kpt file of an image filename would mess up everything.
Thanks.
With which kind of editor did you edit the kpt file ?
Did your tour contained any non-ASCII strings before you edit it ?
Did you save your kpt file with the correct encoding ?
Can you send me the kpt file you backed up before editing it ?
You cand send it to contact@kolor.com .
Thanks Gerald.
I managed to rework it from a backup from the 9th. I don't believe the tour contained non ascii characters. Is the correct encoding for the kpt plain text? I'll see if I can get you that file.
COMMUNITY Forums YouTube channel Google+ |
COMPANY Blog About Kolor Resellers Contact Visit us |
