| User list | Rules | You are not logged in.
Pages: 1
Hi all,
for remote controlling the panogear i know about the touch panel, and papywizard on pc.
What i need is a device that...
- has looooong batterie runtime (4 hours, better 8 when running things like papywizard).
- has the feature to work with predefined shooting pattern (like papywizard does).
My own laptop has a batterie runtime of sixty, with a little luck seventy minutes. And it is heavy and voluminous. So this is only an option in emergency case ;-(
What other devices do you use for controlling the panogear? Atom Netbook, iphone, android phone?
greetings from germany
Chris
Hi
http://www.kolor.com/forum/t16056-panor … -6-android
regards
Fernando
FLA wrote:
Hi
regards
Fernando
Thank you for the link. Unfortunately i don´t have a android yet, so i can´t test it. Does the app support predefined shooting pattern?
greetings from gemany
Chris
Christian Stüben wrote:
Hi all,
Chris
How do you power the Panogear mount so that it has 4-8 hour autonomy?
it has the 12v dc connector for external batterie. Either a big nickel cadmium / nickel metal hydrid or a simple car batterie, with additional 8.1 volt power stabilizer for the camera.
one question to the external power connector ... when i insert a connector, will the internal batteries be disconnected automatically, or have they to be removed to protect them from getting toasted?
Chris
Hi all,
Chris
The TC controller gets it´s power from the head. So if you have plenty of power for the head you also have plenty of power for the controller . .
No need at all for pre-defined patterns - everything gets calculated on the spot in realtime.
And does it optimize the shooting pattern (lesser pictures) when you come near zenith or nadir? If yes, then this would be the hardware of my choice.
And ... does it generate the xml files for apg import? This is an important feature too.
greetings to Düsseldorf
Chris
best, KlausAnd does it optimize the shooting pattern (lesser pictures) when you come near zenith or nadir? If yes, then this would be the hardware of my choice.
Chris
Both items i already explained lenghty several times here
- YES: it of course calculates lesser shots in upper and in lower rows and YES: it writes XML files for positioning in APG using the PapyWizard import.
I use to generate once a "dry" xml-file for each lens i use - this one i can use as a pattern each time i shoot using the according lens. To generate the files i let the head run at home without a camera and load down the xml.
The precision of the head is so high that it´s assured the "dry" recorded positions are absolutely the same as the ones it shoots in the field. I have a folder on my desktop which contains the xml for each lens for shooting spheres or angles.
Important is to use absolutely identical angles of course - with spheres there´s no problem: a sphere always is 360x180° ![]()
So i don´t even need to load down the xml - i already have one for each lens. OF COURSE THATS´S ONLY RELATED TO SHOOTING SPHERES OR ANGLES.
Nevertheless each shooting generates it´s own xml file for being used in APG.
Shooting moasics you load down from the controller the corresponding xml which contains all the start- and end-positions as well as all positions in between - no matter which angles and mosaics you shoot using which lens and
which size of output.
OK then in that case you could also power/charge a Nokia N800/N810 Internet tablet and get 4-8 hours runtime with it running Papywizard.
But you'd probably be better off with the Touch controller.
Chris
You should always remove the internal batteries when using an external power supply.
Hey, why didn´t i find the idea of a pre-made "dry" xml myself? Shame on me.
Not only spheres. Water, large unique areas, new buildings or renovated rooms without any furniture and only blank walls ... without xml support that´s always hard to stitch. Did i say hard? Impossible.
greetings froim germany
So papywizard runs on android? I see, this will be no easy decision ... touch controller or android cellphone ![]()
Thank you for the hint.
Chris
Hi Chris!
I ment: you need a pre-defined pattern only for spheres - because the positions related to a lens/sensor always are the same when shooting spheres. Shooting as angles it depends on how precisely you can set the angle and how precisely the head follows the setting . . ![]()
In mosaic-mode it´s unlikely that you have repeatedly the exactly identical mosaic by setting a start- and end-point related to your motif - so a pattern usually wouldn´t help here: you need to import the recorded xml-pattern from the controller.
But you'd probably be better off with the Touch controller.So papywizard runs on android? I see, this will be no easy decision ... touch controller or android cellphone
Chris
No, Paywizard does not run on Android.
The Nokia N800/N810 Internet tablets (neither any longer in production but widely available used via, say, ebay) run Maemo OS derived from Linux. They are not phones and have no telephony functionality.
http://en.wikipedia.org/wiki/Nokia_N810
http://en.wikipedia.org/wiki/Nokia_N800
But as Klaus suggests, for your needs, it sounds as if you'd probably be better off with the Touch controller.
remote controlling panogear, device with long batterie runtime:
The first complete and professional solution which allows to achieve automatic shooting sessions of tens, hundreds, thousands pictures simply and easily, in order to create high resolution panoramic pictures up to several gigapixels.
Panogear automates your shootings and allows you to design entirely new photo projects. Discover in here the features provided in the Panogear motorized head and its Papywizard software. Remote controlled, precise and versatile: Panogear will allow you to make automatic shootings and to access to new photographic possibilities. Designed to shoot gigapixel images, Panogear will also allow you to automate the creation of time-lapse, bracketing and all kinds of shootings.
Panogear can be connected on choice to a 12V external power supply, either 8 AA standard batteries or 2 rechargeable batteries Li-Ion SB-LSM 160, 7,4V, for an autonomy up to 11h. Batteries and universal charger (outlet, lighter and and adapter) included.
Control Panogear remotely with the help of the Papywizard application and the provided Bluetooth transmitter/receiver. Practical, the remote control prevents you from disturbing your shootings whenever you want to change a setting. It also offers you new perspectives, such as to make shootings on a telescopic mast. The Bluetooth connection of Panogear has a range up to 100 meters. A wire touch controller is also available.
Carry out shooting of dozens, hundreds or thousands of photos in a simple and accurate way to create panoramic images of high resolution up to several gigapixels. Once your images are stitched together, you will enjoy an incomparable level of detail for your prints, your website, to capture a piece of art, or simply just for fun. Panotour Pro: our software for creating virtual tours offers the ability to add sounds, videos, text and even 360° integrated virtual tours to your gigapixel panoramas and to publish the entire project on the internet.
Pages: 1
COMMUNITY Forums YouTube channel Google+ |
COMPANY Blog About Kolor Resellers Contact Visit us |
