#1 2012-09-23 18:35:24
Christian Stüben
Website
photoshop 5.1 and automation
Hi all,
i just wanted to neutralhaze a couple of images. In Photoshop 5.1 i opened on epicture, started record action, neutralhazed it, saved as jpg. Stopped recording.
Then i opend 7 images, tried to automate the recorded action, but neutralhazer open its dialog on every picture.
Why? The action is recorded...
What can i do to automate neutralhazer from photoshop?
greetings from germany
Chris
#2 2012-09-23 18:50:27
Website
Re: photoshop 5.1 and automation
Christian Stüben wrote:
Hi all,
Chris
Did you set recording/action correctly? That´s a bit tricky . . there´s a setting which opens the dialogue for each action seperately . . cool
instead of using the same settings for all pictures in the folder.
I´m not on my Mac with Photoshop - could have a look at it tomorrow!
#3 2012-09-23 23:03:37
Christian Stüben
Website
Hi Klaus,
yes, i already tried to deactivate the dialog checkbox for nh in the action. But unfortunately it cannot be deactivated. Only the action step itself can be deactivated.
greetings to Düsseldorf
Chris
#4 2012-10-09 15:14:54
ygilquin
Website
As stated here http://www.kolor.com/forum/t15738-batch … utralhazer, batch processing cannot be enabled as a same set of values will not produce the same result on every picture. So Neutralhazer will prompt user to adjust settings every time it's applied. I understand this is not the usual way PS plugins work, but by the nature of its processing, Neutralhazer cannot  follow the usual path.
Yann G.
www.kolor.com
