#1 2012-09-11 15:15:09
gigajeff
Problem generating papywizard XML with >100 images per row
Using Papywizard.exe 2.0.0 on windows 7, i am able to create an XML log file. However, if I want to shoot more than 100 images per in a row, I can't do it! I can only specify "100" in that field, and if i press the "up" arrow, the number does not increase sad
using the web-based papywizard xml generator, if I specify e.g. 121 images per row, the XML that it generates does not have that number of images per row (it has 12 instead)
If anyone can help me, I sure would appreciate it!
thank you,
Jeffrey
#2 2012-09-11 15:30:33
gigajeff
Re: Problem generating papywizard XML with >100 images per row
Aha. smile
Version 2.1.22 allows up to 500 pictures in a row.
So I guess I've solved it smile
It would be nice if the web-based generator also worked because that one is "instant". However I can live with this.
cheers smile
Jeffrey
#3 2012-09-11 15:38:14
Website
gigajeff wrote:
thank you,
Jeffrey
Hey Jeffrey!
You can tell the app to start down left and stop up right. Or vice-versa. No matter how much shots it needs: it should work and write the numbers into the XML-file.
Or you can tell the app to cover a certain angle.
Then you can simulate a shooting - and the app gives you the XML.
I´m not sure to having understood correctly what you did!?
(I must say: i don´t know any "Papywizard.exe" at all)
